Focus MK4 no APIM Module visible
michel.schellekens
Vehicle: Fiesta MK8 ST Line 2018 100
Post by michel.schellekens » Sun Jun 16, 2019 9:06 am
I connected with Forscan to my Fiesta MK 8 and the APIM Module became visible and I was able to make the changes.
In my Focus MK4 Forscan sees all modules except the APIM Module.
I tried the following things;
- Disconnect Battery
- Reset Sync
- Drive for a while and try again.
Anyone else who has this problem ? Advice is welcome
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Re: Focus MK4 no APIM Module visible
Post by davetcollection » Tue Jun 18, 2019 7:59 am
Yes, same issue.
Fiesta OK
Focus 3.5 OK
Focus 4 NOK
semiho
Vehicle: Focus Mk4 St-Line Ecoblue A/T
Post by semiho » Thu Jun 20, 2019 2:56 pm
I've configured my car APIM without any problem. Are you sure you have SYNC3? Because mk4 has both SYNC 3 and lite version of it which is called SYNC. I don't know if it could be programmed.
davetcollection
Post by davetcollection » Fri Jun 21, 2019 8:26 am
Hi, can you tell me what version of Forscan you are using and what lead you are using please?
semiho
Post by semiho » Tue Jun 25, 2019 8:04 pm
I guess it it was 2.3.21 and elm327.
olden002
Vehicle: ford focus, 1.0 125pk 2019 st line full options
Post by olden002 » Sun Jun 30, 2019 10:50 am
Hi, I have the same issue, I am sure I have sync 3 with all options.
Tried different versions of forscan, but no APIM pops up.
Any suggestion is welcome?
Michel
stormforce
Vehicle: ford focus stlinex 2018 1.0l ecoboost 140bsp
Post by stormforce » Tue Jul 16, 2019 11:50 am
hello mate have you found how to find apim yet im having the same probs
focus mk 3.5 looking to activate my reverse camera
KdR1337
Vehicle: Fiesta 1.0 125cv 2018
Post by KdR1337 » Tue Sep 10, 2019 11:03 pm
I dont have APIM on my fiesta mk8 without 8" touchscreen.
Bassie
Vehicle: Ford Mondeo/Fusion MK5, 2.0 TDi 180HP, 2015
Post by Bassie » Mon Oct 21, 2019 7:52 am
I assume that you placed the camera harness first, between the APIM and the APIM cable, and then tried to change te settings with forescan. Have you tried to remove the camera harness, then program the APIM (and test if the screen gets black, when you shift into reverse)? And if it works, then reinstall the camera harness.
My guess is, that the camera harness which i bought, has the minimum wires that are needed to function properly, but not enough to program the APIM. Perhaps thats the reason, that i cant find the APIM module.
I'm curious if anyone tried this and if was succesfull?
Because I have the same problem, with my mk5 Mondeo/Fusion: i find a lot of mudules on both hig and medium speed, but no APIM.
So before i deinstall the camera harness, i would like know if someone has tried this before :-)
If this is no option, i'll ask my dealer to change the settings.
Thanks in advance
matt77303
Vehicle: focus mk3 ST3
Post by matt77303 » Mon Oct 21, 2019 12:00 pm
What cable are you using? I’ve been able to program my apim on my focus 3.5.
Matt
