Missing Modules
Fordsme
Vehicle: F150, 3.5 L Eco Lariat, 2018
Missing Modules
Post by Fordsme » Thu Jun 13, 2019 9:36 pm
Hi Is there a reason why I cannot see any other modules than the ones displayed?. I tried Debug mode and normal, reconnected many times, changed USB port, but always the same modules show up. Any ideas?
2018 F150 Lariat 3.5 Eco
Log:
(WARN) [17:26:39.927] Checking WiFi...
(WARN) [17:26:44.930] Checking COM4...
(OK) [17:26:45.285] Connection to adapter has been established: COM4
(OK) [17:26:45.286] Adapter: ELM327 v1.5
(OK) [17:26:45.428] Connection to vehicle has been established
(OK) [17:26:48.597] Vehicle: Ford F-150 EcoBoost Gasoline Turbocharged Direct Injection 3.5L 2018 ( 2018 MY ), VIN: 1FT**************
(OK) [17:26:51.743] Found module: TCM - Transmission Control Module
(OK) [17:26:54.188] Found module: PCM - Powertrain Control Module
(OK) [17:27:04.950] Found module: OBDII - On Board Diagnostic II
(OK) [17:27:05.730] Found module: APIM - Accessory Protocol Interface Module
(OK) [17:27:06.555] Found module: DCDC - DC to DC Converter Control Module
(OK) [17:27:07.697] Found module: PAM - Parking Aid Module
(OK) [17:27:08.574] Found module: BdyCM - Body Control Module
(OK) [17:27:12.157] Found module: BECMB - Battery Energy Control Module B
gg1234635
Re: Missing Modules
Post by gg1234635 » Thu Jun 13, 2019 9:55 pm
sounds like your adapter doesnt support both ms-can and hs-can. which is why you are missing modules
Fordsme
Re: Missing Modules
Post by Fordsme » Fri Jun 14, 2019 1:19 am
It's supposed to be. There is a switch on it and it asks me to switch the speed when reading..
gg1234635
Re: Missing Modules
Post by gg1234635 » Fri Jun 14, 2019 5:50 pm
When forscan starts up it will ask for the profile to load. do not select that one and create a new one. I will then scan for all modules again and not just the ones found in the profile. If at that point it is still not showing. Start forscan with the switch in the opposite position on the adapter that might just kick them in for you. If at that point you still not getting any modules check the following site to make sure you have them installed on your vehicle
http://motorcraftservice.com/asbuilt
if you do then i would suggest trying another adapter or try your adapter on another vehicle that you know does have the modules you seem to have missing and see if they can be found.
My thought would be is that the adapter is at fault and get another one.
