2015 Focus Pats Key Programming
bluepilot
Vehicle: 1996-2016 ford
Post by bluepilot » Sun Jun 09, 2019 10:45 pm
Any news on this 2012-2014 is supported, but 15-16? It has the same key type. Also The function to store the key data in the PCM is also missing. :?:
TimFor
Re: 2015 Focus Pats Key Programming
Post by TimFor » Fri Aug 09, 2019 3:38 pm
Where did you see that 2012-2014 is supported?
For 2017 which should also be Mk3.5 negative previous reply is at viewtopic.php?f=16&t=8432&p=28306
Also a duplicate of viewtopic.php?f=5&t=4120&p=14805
TimFor
Post by TimFor » Sat Aug 10, 2019 2:41 pm
As for 2012-2014 supported, https://forscan.org/download.html says "Focus Mk3 (North America market) 2012-2014 model years". So not clear for European Focus Mk3.
For Focus 2017 which should also be Mk3.5, negative previous reply is at viewtopic.php?f=16&t=8432&p=28306
