Traffic sign recognition on Fiesta MK8 >2017
XE-POR
Vehicle: Mazda 3, LF17 2.0, 150, 2006
Re: Traffic sign recognition on Fiesta MK8 >2017
Post by XE-POR » Sat Jun 13, 2020 7:33 am
hello,roylion15
I have a 2020 focus st line.. Got the values to change in ipma built but when I change them I get service procedure interrupted and no values change. I can PM my Vin ?
Sorry, my English is not good!thanks!
XE-POR
Post by XE-POR » Sat Jun 13, 2020 7:34 am
I had the same problem :cry:
roylion15
Vehicle: Fiesta ST, 1500, Ecoboost, 200 PK, 2019 model
Post by roylion15 » Sat Jun 13, 2020 8:53 am
@imtheju99ernaut
is your IPMA, "H1BT-19H406-AE" part number ?
@XE-POR
topic here is for fiesta mk8, there is another topic for the focus MK4.
Both can send VIN in PM.
No support in PM without invitation, please !
neutron2k
Vehicle: Ford Focus MK4 1.0 125 Ecoboost 2018
Post by neutron2k » Sat Jun 13, 2020 9:17 am
Hi @roylion15
Would you mind helping me as well? Would like to add Traffic Sign Recognition if possible.
I started another thread not realising this thread had focus info in it!
I have speed sign detection at present and monochrome IPC. IPMA is JX7T-19H406-CF
Cheers!
XE-POR
Post by XE-POR » Sat Jun 13, 2020 10:34 am
@imtheju99ernaut
@XE-POR
2020 mk4 STline
IPMA - Image Processing Module A
Part number: JX7T-19H406-DB
Strategy : JX7T-14F397-AJ
Calibration: JX7T-14F398-CB
imtheju99ernaut
Vehicle: ford fiesta st2 1.5 200bhp 2018
Post by imtheju99ernaut » Sat Jun 13, 2020 1:39 pm
@imtheju99ernaut
@XE-POR
Hi roylion my original camera was an ae I’m sure it’s now bd. I can go get the full part number later on if needed.
roylion15
Post by roylion15 » Sat Jun 13, 2020 10:40 pm
Hello
Yes, give me the good part number of the installed cam if it’s not coming from factory, please ...
imtheju99ernaut
Post by imtheju99ernaut » Wed Jun 17, 2020 7:11 pm
Sorry I haven’t replied I have been away working (truck driver) just bad yesterday.
The number on my camera is H1BT-19H406-BD
Now this is the strange part, I have managed to get auto high beam to work by going into to menus on forscan. I enabled auto high beam for the headlights and also for each side. Only issue is I don’t have it in the cars menu, the icon automatically comes on when it’s dark, I have only had it come on once so not sure if it working as normally yet. I should get a better chance to check it over the weekend.
roylion15
Post by roylion15 » Thu Jun 18, 2020 1:16 pm
For AHB ...
need to be enabled in IPMA, SCCM, BCM and IPC
IN IPC to obtain the menu and the AHB light indicator , it's on the first line ....
exemple for a fiesta IPC
720-01-01
0C4A 3464 20 > 0C4E 3464 22
stock xxxX xxxx xY >
X add 4 ( add the AHB menu in vehicle /settings /lighs IPC )
Y add 2 ( AHB light indicator IPC )
As the example
X= A > E
Y= 0 > 2
CoD21
Vehicle: Ford Fiesta MK8
Post by CoD21 » Wed Jul 01, 2020 8:26 am
can i use a "L1BT-19H406-BE"-camera for tsr an ahb for my fiesta? my dealer says its from another fiesta
