Hi All its my first posting so please be gentle, I hope I have posted this in the correct section if not I am sure you will let me know.
2012 Ford Focus Estate 2.0TDCI RHD - Fault Code with IPC U0401:64-2F
Within the last week my trip computer has started to malfunction, when I get in the car all readings Odometer, Dist to empty, Inst Fuel, Av Fuel etc seem to display / function normally, on driving the car 1/2 / 1 mile the Trip computer seems to lose all Fuel related info and only provides readings for Odometer.
I have used FORScan to carry out a check which has provided the above fault code, I have cleared and re-scanned but code comes back, as the code is quite specific I was hoping that someone could offer advice of any connection / sensors to check.
Thanks in advance
Gary
2012 Focus 2.0TDCI - Fault Code with IPC U0401:64-2F
- Vehicle: Ford Focus Estate 2012 2.0L TDCI
Re: 2012 Focus 2.0TDCI - Fault Code with IPC U0401:64-2F
Things it could be 1) bad connection 2) damaged wiring 3) Abnormal system voltages
Run tests on all the modules and post the results if a fault is found.
