Octane Adjust Ratio monitoring?
Dragonheart
Vehicle: Ford Mustang, 2.3L EcoBoost 317hp, 2015
Post by Dragonheart » Sat May 18, 2019 7:43 pm
Hi!
I'm trying to monitor Octane Adjust Ratio parameter available on 2.3 Ecoboost and other Ford motors.
The only similar parameter I've found for PCM module is OCTADJ_R_LRND measured in %. Is this the right one?
Also, other sources like Cobb say it's measured in values from -1.0 (being the best) to 1.0 (being the worst). What is the values range in Forscan? I've seen 76.43% with RON92 fuel, now I have about 90% with RON95. Gonna test RON98 and RON100, but I can't understand how do these percentage values in Forscan correspond to -1.0 - 1.0 range.
Thanks!
HannesK
Vehicle: Ford Mondeo
Re: Octane Adjust Ratio monitoring?
Post by HannesK » Mon Nov 18, 2019 7:47 pm
i tried to read this parameter in my 2019 Ford Focus ST with 2,3 Ecoboost but i cant find this parameter in PCM Module,
is there a possibility to add some custom parameters ?
omar302
Post by omar302 » Tue Nov 19, 2019 11:44 am
I am attaching a screenshot of the PID from my car. You can see the name and change it to Numeric and increase the number of decimal digits.
HannesK
Post by HannesK » Tue Nov 19, 2019 6:03 pm
sorry i forgot to explain that i use the PC Version,
Is it in the PC Version possible to see this parameter ?
omar302
Post by omar302 » Tue Nov 19, 2019 6:10 pm
PID name should still be the same in PC version.
HannesK
Post by HannesK » Sun Nov 24, 2019 6:47 pm
But i found no way to enter the PID Name, there are a lot of PCM Pids available to activate them but i can not find the Ocatan one.
And also no way to enter a custom new PID
omar302
Post by omar302 » Mon Nov 25, 2019 4:18 pm
Here it from the PC version:
The attachment octane.JPG is no longer available
HannesK
Post by HannesK » Tue Nov 26, 2019 11:35 am
Thats what i tried, but this PID is not available in this view for my Focus ST Mk4, does it mean that this parameter does not exist in my Car or that it does not exist in Forscan for my Car ?
omar302
Post by omar302 » Tue Nov 26, 2019 12:50 pm
Honestly don't know. Maybe @ForScan team can chime in.
Dragonheart
Post by Dragonheart » Fri May 08, 2020 3:17 am
Replying after 1.5 years :D
Thanks a lot, changing to Numeric and setting 2 decimal digits did the trick. Now I'm getting correct readings, like -1.0 with RON 100 and RON 98 fuel. Gonna test with lower octane fuels too to check the difference.
