Forscan reset Modules Ford mustang 2015 now transmission doesn't work correctly
rad4633
Vehicle: mustang gt 2015
Post by rad4633 » Thu May 16, 2019 11:28 pm
Tech Question-2015 6r80 paddle shifters in S mode not working, IPC won't display gear numbers or work and if you try using S mode then go back to D mode, gear numbers pop up and trans starts downshifting to 1st and wont change until I reset module then as long as left in D works perfect. issue started after reset of modules with Forscan-as built in data has been installed many times by dealership to ensure latest V. was installed to BCM,BCM-Y, and PCM,IPC etc still no displaying on numbers in S mode, paddles non operational. suggestions?
