Tire pressure monitor fault Ford Escape 2012
jcascog86
Vehicle: Escape 2012 2.5cc
Post by jcascog86 » Thu May 16, 2019 12:34 am
Hello to all
I have an issue with my escape 2012, I'm driving the car without any problem but sometimes the.little screen on the dash shown tire pressure monitor fault and the light of tpms, door open and emergency brake are on like the picture attached, when this warning appear the other ligth like Hazzard won't works and the AC compressor won't work as well
denbo
Vehicle: ford focus 16 zetec
Re: Tire pressure monitor fault Ford Escape 2012
Post by denbo » Fri May 17, 2019 3:57 pm
Did you scan for faults? I would start with a battery check.
jcascog86
Post by jcascog86 » Mon May 27, 2019 1:18 pm
Yes and i can't see any fault, is there any way to show you a log of the scan?
Which battery? the engine's battery? If this is, I already changed with another one
theandies
Vehicle: 2015 Ford Explorer, 2016 Ford Fusion
Post by theandies » Wed May 29, 2019 9:25 pm
I was going to say you probably need to relearn the TPMS sensors. Search for how to do it for your model. I just went through this with my 2016 Fusion after enabling the 4-wheel tire pressure screen on my left instrument cluster. But after reading you post and you have other issues that may not be the problem. I agree that your battery may be going. Good luck.
