PAM Internal Component Failure
karlv
Vehicle: Mondeo, diesel, 2l, 2012
Post by karlv » Mon May 13, 2019 8:29 am
Hi, can any help me out I have ran a scan and I it was showing as below:
Code: B1B50 - Rear Left Inner Sens
Additional Fault Symptom:
- Component Internal Failure
Status:
Module: Parking Aid Module
Freeze Frame :
-GLOBTIM: 0 sec - Global real time
-TOTDIST: 0.0 km - Total Distance
-MAINECUV: 0.00 Volt - Main ECU voltage supply
-ESTSECRK: No - Engine status - engine in crank
-ESTSERUN: No - Engine status - engine running
-INCARTMP: -40 °C - In car temperature
I replaced the Sensor with a new sensor ran the scan and then it was saying Electrical fault and all my PAM's were showing as faulty. I then ran the service procedures and cleared the DTC's ran the test again and I am now back at the start and it is showing as a 'Component Internal Failure' rear left sensor I have checked the wiring for the rear left sensor and all looks fine. I have checked the connections to the module and all are seated correctly. Can anyone help me out this is driving me crazy!
denbo
Vehicle: ford focus 16 zetec
Re: PAM Internal Component Failure
Post by denbo » Mon May 13, 2019 7:02 pm
Take that sensor back out and do a scan. Its possible the module don,t like it. Where did you buy it?
karlv
Post by karlv » Mon May 20, 2019 7:49 am
Hi Denbo, when I take that sensor out and run the scan I get a 'General Electrical Failure' fault. I purchased it from Transit Parts when I swap it for the inner right sensor it then shows the inner left fault and with no sensor it says as above. This suggests the sensor is fine. It has worked once or twice in the past month but it will work and then if you put the car into reverse say 5 minutes later I get the continuous noise then nothing again. Could this be the module or faulty wiring somewhere? Thanks
denbo
Post by denbo » Mon May 20, 2019 7:49 pm
If it works ok on another plug then i would go for a wiring fault. Did you test the old sensor the same way?
