Error when writing PCM
c.piano
Vehicle: Fiesta MK8 1.5 85cv
Post by c.piano » Fri Apr 26, 2019 9:01 pm
I get error (service interrupt) when I’m going to write PCM on fiesta mk8.
Anyone knows if last version of Forscan can write parameters on this module?
I don’t know if my adapter isn’t good or the problem is that the last version can’t write PCM yet :?:
Vehicle: *** Ford ***
Re: Error when writing PCM
Post by f-wolf » Sat Apr 27, 2019 1:30 am
Try an older version of Forscan
It may work ??
c.piano
Post by c.piano » Sat Apr 27, 2019 1:10 pm
Hi!
I tried all versions since the .16! Writing PCM not working.
.16 version.
.17 version.
.18 version.
.19 version.
.20 version.
And the last .21 version.
Writing on APIM and BCM it’s ok.
The problem it is on writing PCM. It is only mine problem?
Amornthept
Vehicle: Ford, BI TURBO, 2018
Post by Amornthept » Sun May 19, 2019 7:59 am
I have the same issued and try to solve for long, finally I remove an Obd2 ultraguge (Ford have 2 OBDII port) then can writed with ELM327. :lol:
