Ford Fusion 2010 SEL faults
VanDeursen
Vehicle: Ford Fusion
Post by VanDeursen » Thu Apr 04, 2019 2:25 pm
Dear all,
My wife owns a Ford Fusion 2010 SEL already quite some time even from before we met.
Now this car is full with things... And we are solving them one by one.
Here is the log.
Code: Select all
==PCM DTC P0060:00-EC===
Code: P0060 - HO2S Heater Resistance (Bank 2, Sensor 2)
Status:
 - DTC Maturing - Intermittent at Time of Request
 - Malfunction Indicator Lamp is On for this DTC
 - Test not complete
Module: Powertrain Control Module
===END PCM DTC P0060:00-EC===
===PCM DTC P0130:00-E8===
Code: P0130 - O2 Sensor Circuit (Bank 1 Sensor 1)
Status:
 - Previously Set DTC - Not Present at Time of Request
 - Test not complete
===END PCM DTC P0130:00-E8===
===PCM DTC P0325:00-68===
Code: P0325 - Knock/Combustion Vibration Sensor 1 Circuit (Bank 1)
Status:
 - Test not complete
===END PCM DTC P0325:00-68===
===PCM DTC P0625:00-E8===
Code: P0625 - Generator Field/F Terminal Circuit Low
Status:
 - Test not complete
===END PCM DTC P0625:00-E8===
===PCM DTC P1000:00-2B===
Code: P1000 - OBD Systems Readiness Test Not Complete
Status:
===END PCM DTC P1000:00-2B===
===OBDII DTC P0060-C===
Status:
 - Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0060-C===
===OCS DTC None===
Successful DTC reading, no error codes found
Module: Occupant Classification System Module
===END OCS DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC U3003:68-08===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
 - Event Information
Status:
Module: Power Steering Control Module
 Freeze Frame :
-SWRS: 0 rev/min - Steering Wheel Rotation Speed
-SW_ANGLE: -350.00 ° - Steering Wheel Angle
===END PSCM DTC U3003:68-08===
===IPC DTC U0161:00-08===
Code: U0161 - Lost Communication With Compass Module
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0161:00-08===
===ABS DTC B1342-E0===
Code: B1342 - ECU internal fault
Status:
Module: Antilock braking system
Diagnostic Trouble Code details
ECU internal fault
===END ABS DTC B1342-E0===
===ABS DTC C1175-20===
Code: C1175 - Left Rear Wheel Speed Sensor Input Circuit Failure
Status:
Sensor
Short circuit
Open circuit
Sensor Previously disconnected.
This DTC may be caused by :
Damaged or contaminated connector
===END ABS DTC C1175-20===
===ABS DTC C1155-20===
Code: C1155 - Left Front Wheel Speed Sensor Input Circuit Failure
Status:
Sensor
Short circuit
Open circuit
===END ABS DTC C1155-20===
===ABS DTC C1145-20===
Code: C1145 - Right Front Wheel Speed Sensor Input Circuit Failure
Status:
Sensor
Short circuit
Open circuit
===END ABS DTC C1145-20===
===ABS DTC C1165-20===
Code: C1165 - Right Rear Wheel Speed Sensor Input Circuit Failure
Status:
Sensor
Short circuit
Open circuit
===END ABS DTC C1165-20===
===DSP DTC U0197:00-0A===
Code: U0197 - Lost Communication With Telephone Control Module
Status:
Module: (Audio) Digital Signal Processing Module
===END DSP DTC U0197:00-0A===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===GPSM DTC U0423:00-88===
Code: U0423 - Invalid Data Received from Instrument Panel Cluster Control Module
Status:
Module: Global Positioning System Module
===END GPSM DTC U0423:00-88===
===FCIM DTC None===
Module: Front Controls Interface Module
===END FCIM DTC None===
===FDIM DTC U0197-60===
Status:
Module: Front Display Interface Module
===END FDIM DTC U0197-60===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===ACM DTC U0197-60===
Status:
Module: Audio Control Module
===END ACM DTC U0197-60===
===GEM/SJB DTC B2872-E0===
Code: B2872 - Tire Pressure Sensor Fault
Status:
Module: Generic Electronic Module / Smart Junction Box
This DTC indicates the module is not receiving data from one, two, or three of the TPMS sensors. Possible causes include sensor(s) programmed to the module are no longer present or no longer functioning. Make sure there are operating sensors in the wheels and they are trained to the module.
In rare cases, this DTC can be set by radio frequency interference with consumer electronics. Cell phone chargers, power converters and power supplies have been found to be likely candidates.
===END GEM/SJB DTC B2872-E0===
- On the moment the HO2S sensor will be replaced.
- The tire pressure sensor TPMS rear left is also replaced but we can't erase or connect the sensor to the system by the program. If someone have an idea please? Or this goes automatically?
- ABS i guess this complete module need to be replace?
- Generator Field/F Terminal, the alternator what isn't good?
- Phone module is also kind of weird...
If someone can give advice please?
VanDeursen
Re: Ford Fusion 2010 SEL faults
Post by VanDeursen » Sun Jul 07, 2019 5:44 pm
I mean time I exchanged H02S sensor Bank 1 & 2, the knocking sensor was loose (fixed), replaced the fan blower ecu with a new one.
Still need to replace the ABS electronic module and alternator. And the TPMS need to be reset (struggeling link)
log currently is already more clear.
Code: Select all
===PCM DTC P0625:00-D0===
Status:
 - Test not complete
===END PCM DTC P0625:00-D0===
Status:
===OBDII DTC None===
===END OBDII DTC None===
===OCS DTC None===
===RCM DTC None===
===PSCM DTC None===
===END PSCM DTC None===
===IPC DTC None===
===END IPC DTC None===
Status:
ECU internal fault
Status:
===HVAC DTC None===
===GPSM DTC None===
===END GPSM DTC None===
===FCIM DTC None===
Status:
===PAM DTC None===
Status:
Status:
