mileage correction
markseswick42
Vehicle: ford galaxy diesel 1.8tdci 07
Re: mileage correction
Post by markseswick42 » Tue Jul 16, 2019 7:22 pm
Does anyone know an hour to increase milage
Scott2373
Vehicle: F150, 2.7TT/2018
Post by Scott2373 » Sat Sep 21, 2019 1:25 am
What's the latest on this? I need to increase the mileage on my IPC after a swap.
Vehicle: Ford XR6 Turbo BA MK II 6 Speed Manual
Post by f-wolf » Sat Sep 21, 2019 2:09 am
Changes History
+ Added feature
* Improved/changed feature
- Bug fixed/removed feature
2.3.24 beta, 2019-08-05 (download)
+ Vehicle database update
+ Some BdyCM module configuration parameters for:
Edge 2015-2019 model years
Expedition 2018-2019 model years
Lincoln Navigator 2018-2019 model years
Ka/Figo 2018 model year
+ Some IPC module configuration parameters for:
Explorer 2020 model year
Kuga/Escape 2017+ model years
+ Some APIM/SYNC3 configuration parameters
+ Configuration and programming procedure "Central configuration" for:
Escape 2019 model year
Transit (V363, North America market) 2019 model year
+ Configuration and Programming function "Odometer write" (can only increase mileage!) for :
Ranger 2011 model year
Ranger 2015-2019 model years (experimental)
+ Configuration parameter "Engine Sound Enhancement" (enable/disable) for ACM modules of:
Ecosport 2018 model year
Fiesta 2017 model year
Focus Mk4 2018 model year
+ Service function "PATS Programming" for:
Transit (North America) 2015-2016 model years
+ Service procedure "DPF Static Regeneration", "Reset the Diesel Particulate Filter Learned Values", "Reset Differential Pressure Sensor Learned Values" for:
Everset 2.2/3.2 TDci 2015 model year
Mondeo 5 1.6/2.0 TDCi 2015 model year
S-Max 2.0 TDCi 2015 model year
+ Service functions BdyCM "Local Interconnect Network New Module Calibration", (used for rear camera calibration but not only), "Tire Pressure Monitor learning mode", PSCM "Calibrate Steering Angle Sensor", RCM "Crash Flag Reset" for:
+ returned back "Module initialization/relearn vehicle data" function for Mazda Skyactiv mistakenly removed in previous release
* fixes and improvements in configuration and programming procedure "Trailer tow activation"
* improvements in service function EPS "Calibrate Steering Angle Sensor" for Mazda 6 GH (after facelift): added important information about initial conditions. Thanks to Alexander (lightning)
- crash bug during connection to diesel cars with FIP/ICU modules (Focus/Mondeo/Transit 1999-2005)
- unability to write DDM/PDM As Built Data for:
- unability to write IPC As Built Data for:
Focus Mk4 2019 model year (May-July)
- bug in parsing some *.AB files
Go to:
Next ...Hold down Ctrl key ... and hit the F key ... and do a word search for Odometer write
There should be 10 ... Have a read !
