MAF sensor diagnose
MAF sensor diagnose
Hello !
i noticed it
S-Max 2.0 TDCi 110kw
Ignition key the ON position, engine not running and MAF sensor shows 2,11 g/s
this is normal ?
Donny
Re: MAF sensor diagnose
Post by Donny »
That is not normal. It should read 0 when the engine is not running.
I don't know the exact figures for your engine, but at tick over I would expect it to be somewhere around 6 or 7 and be steady, and rise to high double figures under extreme load.
Hopefully someone with the same engine as you can confirm the normal expected values.
Vehicle: *** Ford ***
Post by f-wolf »
These are the readings from a MAZDA 3 2L Petrol 2010
Ignition on Engine NOT running
Engine not running.jpg (54.45 KiB) Viewed 3779 times
And
Engine running ... Idling at about 750RPM
Engine Idling.jpg (54.5 KiB) Viewed 3779 times
Try to clean your MAF Sensor with Sensor Cleaner first ...
Thanks !
when the engine running 800rpm and maf 12g/s
i can't find the Forscan MAF sensor volt PID-s only MAF g/s and MAF hz
car mileage is 25000km
I installed a new maf sensor today, the result is same 2.11 g/s :roll:
Pg502
Vehicle: Mustang, v6, 2011
Post by Pg502 »
Quick question
Can forscan via pc read the voltage from a MAF sensor ?
Post by f-wolf »
Yes !!
Engine Idling.jpg (55.39 KiB) Viewed 3299 times
Pg502
Post by Pg502 »
So I have stalling and hesitation at idle for my 2011 mustang.
On forscan it shows g/s is around 5 and but the volts are at a constant “0”. What does that mean ? (Idle )
Pg502
Post by Pg502 »
4g/s***
WALK3R
Vehicle: Ford Trasit 2012
Post by WALK3R »
Pg502 wrote:
Fri May 24, 2019 1:56 am
Sounds like your maf is broken, try back probing it for voltage.
