Paullk8232
Vehicle: 2016 f350 6.7 diesel 440hp
Post by Paullk8232 » Sat Mar 24, 2018 5:09 pm
Update here, one of Chinese DB9 breakouts was different than the other, I am able to connect with can lab now at 125k and 500k for low and high speed networks. Still no luck with FORScan though.
Beano
Vehicle: Ford FGX XR8 5.0L Coyote Supercharged 400rwkw
Post by Beano » Sun Apr 01, 2018 12:56 am
Hello Forscan,
I am busy testing an older Mongoose PWM/CAN with FEPS for Ford on your software. I can confirm the software sees the device and make connection to it without problem.
I will test connection to the car and reading of parameters in a few hours. So far this seems to be a go.
edit: I can confirm the above adapter works in Win7 environment with Forscan sw. Hopefully soon I can update it to Mongoose Ford Pro and have it run in Win10 environment - will retest an feedback then.
Cheers,
Beano
Divad968
Vehicle: bmw E82 2013
Post by Divad968 » Sat Jun 02, 2018 11:26 am
I have been a Ford Master Technician for 30 years and used about every brand diagnostic scanner?Autel Maxisys Elite over the years and this one is hands down the best and most universal scanner I have used to date! Never once have I had an issue with the Blue Tooth connection between the scanner and the VCM unlike what we use at Ford. Programs keys perfectly, bi-directional controls work flawless and is very fast processing of live data....WAY faster than Snap On Versus and the software especially for Ford is almost identical to Fords software with the IDS we use at the dealership...I actually prefer my Autel over the IDS now.
gimi87
Vehicle: Fiesta, Petrol 1.3/70KM, 2006
Post by gimi87 » Sat Jun 23, 2018 8:52 pm
Hello :) I'm developing a J2534-1/2534-2 device based on the STM32 microprocessor. I have a two CAN-buses and one ISO9141 bus. Forscan is working properly with my PassThru driver, but i can't run the J2534-2 part which is handling MS-CAN. Is there any chance to provide a custom device name which will handle the J2534-2 part (in a textbox or as an application parameter)?
EDIT: Connecting to the J2534-2 is working without passing a device name. Somehow FORScan started trying connecting to MSCAN protocol byself. It is working with my custom device.
Clevorlane
Vehicle: 2005 F150 5.4 3V 300hp
Post by Clevorlane » Fri Jul 27, 2018 11:34 am
Hi everyone,
I'm new to this forum but have many years experience in calibration on vehicles. A search for a good Ford CAN software came up with FORScan but I can't connect it to my interface. This is a J2534 from PEAK called PCAN-USB type IPEH-002021. FORScan ( 2.3.16 beta ) does not find the device. Under devices on my Windows 7 laptop it is shown and status is ready. Can I manually choose what J2534 device to use in FORScan?
Thanks, Sebastian
doublehex
Vehicle: transit 2.2 2009
Post by doublehex » Sat Aug 25, 2018 12:02 pm
i have mongoose gm lead passthrough it works with most fords
will nit connect to some mondeos around 2006 year
Albegx
Vehicle: Mondeo 4 PantherBlack 240
Post by Albegx » Sun Sep 30, 2018 11:20 pm
For the scan there is no adaptation of forks and clutch on the Mondeo 4 2011.WTF? :?:
boovy
Vehicle: Ford Focus MK3 1.6 diesel 2011
Post by boovy » Mon Oct 29, 2018 2:40 am
FORScan wrote:
Mon Mar 28, 2016 7:10 am
As far as we can see on the page, the adapter doesn't support J1850 (used by European Fords up to 2006 and US ones up to 2009). Other protocols (except specific like UBP) should work.
link is dead ,careucar is updated to obd2eshop,correct link is:
http://www.obd2eshop.com/wholesale/mogo ... honda.html
copano
Vehicle: Ford Escape 2015
Post by copano » Fri Nov 16, 2018 3:32 am
This was asked in this thread before but no one replied to him, so I'll also ask if anyone has tested the VCI-Mini J2534 for Toyota
with Forscan.
Dirt cheap on Ebay
https://www.ebay.com/itm/MINI-VCI-Inter ... 1438.l2649
wolf_walker
Vehicle: 2004 Lincoln Town Car Ultimate
Re: UBP
Post by wolf_walker » Fri Dec 07, 2018 9:58 pm
FORScan wrote:
Mon Aug 31, 2015 10:55 am
S117MC wrote:Will a J2534 adapter allow access modules on the UBP network? Can FORScan access them?
Well, from all J2534 adapters we saw only Ford VCMII does support UBP... And no, UBP is not supported for J2534 yet as testing of UBP is not successful yet (we had no chance yet to get a local access to a vehicle with UBP - as it is US market specific). If anyone has J2534 with UBP support and vehicle with UBP support, we are ready to cooperate (do necessary tests and implement normal support in FORScan).
This might be a dumb question (I'm still learning) but if one was to use a VCMII clone from china(assuming it functioned), would FORScan be able to see modules on the UBP buss then? 2004 Lincoln Town Car, still a couple of modules I can't access.
