2018 Ford F150 not all modules showing up
elitedja
Vehicle: mercury, 4.0 liter, 2005
Post by elitedja » Fri Jan 25, 2019 4:10 pm
Hi let me say that I have been using forscan for about 1 1/2 now and it has always worked perfectly. I have the latest version installed and I connected to a 2018 Ford F150 the other day so that I could set up the RCM and when Forscan connected the RCM as well as a bunch of other modules never showed up.. I only saw PCM, TCM, BCM, PAM and APIM that was it.. Does anyone know if this is a glitch or can Forscan not "talk" to the other modules anymore. Again every time I have used the program it has always picked up every module in the vehicle. I am from the United States if that matters. Thanks in advance BTW I am connecting with J2354 and always have
Dan
Andyfocus
Re: 2018 Ford F150 not all modules showing up
Post by Andyfocus » Sat Jan 26, 2019 4:06 pm
first check the settings tab to make sure you are reading both hs and ms can (forscan tends to change some settings on reinstall due to changes made by the devs they sometimes change the odd setting in options )
could be a bug in the new software ? try going back to a slightly older version , if it shows send a bug report to forscan .
also have you tryied turning the ignition on and off a few times then try to connect think someone had a few modules not showing up on f150 and cycling the ignition sorted his problem out .
also is it a new rcm if it is it wont talk to forscan untill you run as built data on it , to do this run an old profile with the rcm detected , then goto programming and the rcm will be their with the opion to load as built data on it ,
dont try to read or erase fault codes etc as it will fail untill its reading the module .
once you have ran the as built disconnect forscan cycle ignition and try to read the car again without a profile to see if it detetects the module.
airbornefubar
Vehicle: F150 2.7L Ecoboost 2018
Post by airbornefubar » Sun Jun 23, 2019 4:46 pm
I only see HSCAN when i hit the modules tab. How do I see MSCAN?
Doubledown
Vehicle: Ford F-150 Raptor, 3.5 eco boost 450hp, 2018
Post by Doubledown » Mon Sep 02, 2019 4:51 pm
I’m having the same issue, not finding the MS modules. Did you ever find a solution?
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Mon Sep 02, 2019 5:53 pm
You use the hs/ms switch,,, if you have one.
Doubledown
Post by Doubledown » Mon Sep 02, 2019 7:01 pm
I used the switch when it prompted me to. No MS modules come up. I also tried selecting “no” when the vehicle profile comes up, still no luck.
