2012-2013 Boss 302 Track Key Service Procedure
bluepilot
Vehicle: 1996-2016 ford
Post by bluepilot » Mon Jan 14, 2019 2:54 am
So I am trying to enable the track key feature on a 2012 boss 302. I enabled it in the cluster but it does not recognize the red track key. In IDS it is a service procedure in the body section. I've checked as built against a laguna seca boss 302 (these cars came with the track key enabled) and still no track key activated display in the cluster. I need to do this before I can flash the PCM with with the new track key calibration... Thoughts?
