Ford Ranger 2011-Present for P375 & LARIAT
narrco
Vehicle: Ford Ranger Wildtrak (P375/J26E) 3.2 TDCI 2016
Post by narrco » Fri Jan 11, 2019 1:10 am
Lads & Gents,
Please help us to share any FAT information that you have on this Model. This is for Study Experiment and Experience among of us.
Sharing is Caring.. ;)
Sharing each other for improvement!!
narrco
Re: Ford Ranger 2011-Present for P375 & LARIAT
Post by narrco » Fri Jan 11, 2019 1:14 am
Do you have a Spreadsheets Code Module Programming List for model. Please share & thanks
narrco
Post by narrco » Fri Jan 11, 2019 3:35 am
FORScan wrote:
Fri Jun 23, 2017 11:28 am
Here are some very helpful resources created by enthusiasts:
1. Tutorials:
Great FORScan tutorial created by Livnitup from F-150 forum. It was developed for F-150, but the principle of work with As Built data can be applied to any model.
2. As Built decodings
2015-2018 F-150s created by Livnitup from F-150 forum.
2013-2017 Fusion created by DanMc85 from 2GFusions forum.
2011-2018 Explorer's created by PlatinumOwner from the Explorer forum
2017 Ford Super Duty models F250, F350 and F450 created by EpicCowlick from Ford Trucks forum.
3. Related threads on enthusiasts forums
FORScan - software to enable/disable features in your truck - Ford F150 Forum - Community of Ford Truck Fans
2GFusions HOW TO: FORScan - Modify Module As-Built Data
Ford Trucks FORScan Spreadsheet
4. Official resources
Motorcraft - Module As-Built Data (returns factory data by VIN)
5. Other resources
Sync 3 APIM Programming
narrco
Post by narrco » Fri Jan 11, 2019 3:36 am
Kyranr wrote:
Thu Jan 05, 2017 5:41 am
My XLS came with 255/70/16 tyres. The formula to figure out the nominal circumference of the tyre size is ((255 * 70 * 0.02) + (16 * 25.4) ) * Pi(3.14159). Result is 2398.2898. Multiply that by the conversion factor of 96.7% and you get 2319mm rounded off.
My “As Built” HEX at address 726-12-01 is 0163 0910 510E. 0163 is the diff ratio and 0910 is the tyre size. If you take 0910 in hex and convert to decimal you get 2320mm so its within 1mm.
So 285/75/16 tyres equal 2533mm. 2533 converted to HEX is 09E5 So when then you write 0163 09E5 51XX into address 726-12-01 the speedo will be correct. Don’t worry about changing the xx Forscan will calculate the checksum for you.
This does bring up a DTC in the PCM which can be seen with Forscan but doesn’t seem to affect anything.
This is for the MK2 so your address will be different. Try searching your As Built data for "0910" or send me your VIN and I will see if I can work it out.
0163 0910 510E is the mk2 manual.
0175 0910 5120 is the mk2 auto.
narrco
Post by narrco » Fri Jan 11, 2019 3:37 am
f-wolf wrote:
Tue Jul 24, 2018 1:44 am
Just see if this is of any help ...
https://docs.google.com/spreadsheets/d/ ... =815852466
narrco
Post by narrco » Fri Jan 11, 2019 3:42 am
ThomasD1962 wrote:
Sat Aug 04, 2018 7:40 am
There are five themes (as I understand it); Timeless (which is standard), Classic (same but more colors), GT, Lincoln Timeless and Lincoln Next.
ST doesn't have it's own theme, just the start and end screens.
And here are the numbers!
7D0-03-01: xxxx 00xx xxxx - Ford Classics theme
7D0-03-01: xxxx 01xx xxxx - Ford Timeless (default)
7D0-03-01: xxxx 04xx xxxx - Ford GT performance
For the Lincoln theme’s first do 7D0-01-02: 8xxx xxxx xxxx
7D0-03-01: xxxx 02xx xxxx - Lincoln Timeless (Gold Theme, Black Icons)
7D0-03-01: xxxx 03xx xxxx - Lincoln Next (Gold Theme, White Icons)
Splash screens:
7D0-02-01:
Standard Ford logo; XXXX 0106 XXXX
Lincoln logo; XXXX 0401 XXXX
Lincoln Black Label logo; XXXX 0301 XXXX
Ford Raptor logo; XXXX 0501 XXXX
Ford Mustang logo; XXXX 0601 XXXX
Ford GT350 logo; XXXX 0701 XXXX
Vignale Classic; XXXX 0801 XXXX
Ford GT350R logo; XXXX 0901 XXXX
Ford Performance ST logo; XXXX 0B01 XXXX
Ford Performance RS logo; XXXX 0C01 XXXX
Ford Performance GT logo; XXXX 0D01 XXXX
Lincoln Continental logo; XXXX 0E01 XXXX
You're welcome!
