MyKey, 2014 Fusion Hybrid Titanium
papab2010@gmail.com
Vehicle: Ford Fusion Hybrid Titanium
Post by papab2010@gmail.com » Wed Jan 09, 2019 9:52 pm
I bought this 2014 Ford Fusion Hybrid Titanium and it only had one MyKey, no Admin key. I now know that was unwise but here I am. I have the OBDII scanner with the MS/HS switch. The issue is for me, I don't know where to find the files I need to work with to format the MyKey to an Admin Key. I have found some really nice spread sheets on Forscan for altering other settings which have worked great, but no mykey. I have the Extended Use plan through ForScan as well. Any help is welcome. If you feel you need to take a pot shot at being a dummy for only getting one key, feel free. I earned it.
Andyfocus
Re: MyKey, 2014 Fusion Hybrid Titanium
Post by Andyfocus » Sun Jan 13, 2019 9:11 pm
haha dummy meet dummy i did same rofl ,
anyway check for pats in forscan if u have it then go get a key of ebay and correct transponder chip get key cut , then reprogram the keys using forscan and they both will be admin keys ;)
