lollapalooza
Post by lollapalooza » Wed Oct 10, 2018 6:50 am
I'm sorry I cannot help. Maybe you can try and contact the developers.
Romad
Vehicle: 2017 Ford F-150 King Ranch 5.0L
Post by Romad » Wed Oct 10, 2018 4:48 pm
Did you make sure to install the key into Window's Registry, before going back into Forscan. In windows 10 you can Right Click on the License.key and click on Merge. It will ask you do you trust this source. Click OK, that you trust the source, and it will load the key into registry. THEN go back into forscan and you should be able to load the license in.
tazzbr60
Vehicle: 04 f150 xlt
Post by tazzbr60 » Wed Oct 10, 2018 6:27 pm
It does not give the "Merge" option when I right click on the key in Windows 10.
tazzbr60
Post by tazzbr60 » Wed Oct 10, 2018 6:38 pm
I even edited the key in the registry with the string from the license and it made no difference either.
tazzbr60
Post by tazzbr60 » Thu Oct 11, 2018 3:53 am
I finally had to manually edit the ID and the license strings in the registry in order to get this extended license to work, no matter how many times I loaded the license in the software it would not update the registry entry.
jamesswright
Vehicle: 2006 Ford F350 6.0L
Post by jamesswright » Mon Oct 22, 2018 8:47 pm
I am having a problem with the extended license with winows 10, also. Worked fine on XP pro, can't get it to work on the new laptop. Any help would be appreciated.
tazzbr60
Post by tazzbr60 » Mon Oct 22, 2018 10:21 pm
I had to manually enter the info from the license into the registry to get mine to work.
tazzbr60
Post by tazzbr60 » Mon Oct 22, 2018 10:28 pm
Make sure the forscan program is closed when you make these edits!
If you open the license with notepad, it will give you the registry path, and then just copy and paste the key info to the registry line then save the changes.
jamesswright
Post by jamesswright » Mon Oct 22, 2018 10:44 pm
Thanks for the response Tazz, But I am pc illiterate, I've been a MAC user for the last 10 years. Windows is completely foreign to me. Can you explain that in Dummy terms?
tazzbr60
Post by tazzbr60 » Mon Oct 22, 2018 11:21 pm
lol..I will try, here goes..
First locate the license that you downloaded from Forscan
right click on the license and open with notepad, once that is done you will see something like this:
REGEDIT4[HKEY_CURRENT_USER\Software\Astech\FORScan]"Key"="2lHeNEkPEm..........
Let that stay open for the moment and find the windows icon in the lower left corner of your screen, right click on the icon, choose run..then type REGEDIT and click ok, once the registry is open..follow the path above..HKEY_CURRENT_USER\Software\Astech\FORScan...hope you are still with me so far...lol
The id string should match the hardware id that was provided by the forscan application...if it does not then you will have to modify it as well....
to modify these strings you will need to right-click on the word "id" and choose MODIFY..then only change the "value data" in that field if needed.
copy the "key" from the notepad without the quotes and paste into the key string of the registry string..should look like this..2lHeNEkP............gvi6AK39bFg=
Hope this helps, I am not too good at technical writing
