Auto Start Stop Disable Success 2019 Ford Edge
bsadek
Vehicle: Ford Edge 2019
Post by bsadek » Sun Dec 16, 2018 12:28 pm
I successfully disabled the Auto Start Stop Feature on my 2019 Ford Edge Titanium
I hope this helps someone.
Forscan Version 2.3.18 Beta
Windows 10
OHP WiFi Forscan OBD2 Adapter Scanner with HS-Can & MS-Can Switch
Body Control PID: 726-48-02
Body Control PID Original value: 0100 0000 xxxx
Body Control PID New value: 0000 0000 xxxx
YouTube Procedure that I used to turn off Auto Start Stop
https://www.youtube.com/watch?v=uAQ6kiHofG0
Bill
2019 Ford Titanium AWD
matt8686
Vehicle: 2019 Ford Edge ST 2.7L TT
Re: Auto Start Stop Disable Success 2019 Ford Edge
Post by matt8686 » Sun Dec 30, 2018 2:47 pm
hi Bill,
I am planning to do the same thing with my '19 Edge ST. I hate the Auto Start/Stop feature.
I am waiting for my ODB II adapter to ship.
I have ForScan 2.3.19 beta.
Was the process simple? How long did it take? I'm slightly anxious making a mod to my vehicles software/firmware... Have you done any other mods?
Thanks!
-Matt
dongqiyer
Vehicle: ford edge 2.0t 2017
Post by dongqiyer » Fri Jan 04, 2019 3:31 am
i have done it with my edge 2.0t 2017, by changing BCM No.726-48-02 from *1** **** **** to *0** **** ****.
big_si
Vehicle: custom, diesel, 2.0/130 2019
Post by big_si » Mon Feb 25, 2019 5:23 pm
I did this on my works van ford custom 2019 and it works awesome thank you
edortaprz
Vehicle: Focus 2017
Post by edortaprz » Mon Mar 18, 2019 6:20 pm
Hi!
Disabling SS via 726-48-02 disable system completely or you can able it manually with the switch?
Thanks in advance.
big_si
Post by big_si » Mon Mar 18, 2019 8:11 pm
once you disable it through 726-48-02 you can only re enable it through 726-48-02 the dash button will still work but it won't enable or disable the stop start function
edortaprz
Vehicle: Focus 2017
Post by edortaprz » Tue Mar 19, 2019 3:22 pm
It not the ideal way but better than nothing :lol:
Thanks a lot.
I am editing as I can not find that 726-48 into my car, I can only see from 726-01-01 to 726-01-05. Photo below. Someone know why?
https://imgur.com/xVDA7qQ
Thanks in advance.
ldrider82
Vehicle: Fusion 4cyl 2012
Post by ldrider82 » Tue Dec 03, 2019 2:24 pm
Since there is no such thing as a silly question, here goes: Does disabling the auto stop start affect the warranty?
wullboy
Vehicle: Ford Ranger 2.2 limited 2016 [ face lift ]
Post by wullboy » Wed Dec 04, 2019 9:45 am
I would say Yes m8, that why you should keep a back up of your modules, that way you can revert back to the " as build " for when you are taking it back to the garage to work on it..
ldrider82
Post by ldrider82 » Wed Dec 04, 2019 2:39 pm
Roger that.
