B1218 Transmitter Identification Code 2017 Fusion
LahainaOhana
Vehicle: Fusion, Gas 2.5L, 2017
Post by LahainaOhana » Wed Dec 05, 2018 2:23 am
I purchased a 2017 Fusion S with 600 miles that was in the Texas flood. I've got most all the errors corrected, however the key, (the only one) I got with the car will start the engine if it is in the cup holder, but won't lock/unlock or do any remote functions. I changed the battery in the remote. This is the DTC error. Forscan says there are no errors in the RTM. Do I just need to take the key into the dealer to get it programmed?
Andyfocus
Re: B1218 Transmitter Identification Code 2017 Fusion
Post by Andyfocus » Sat Dec 08, 2018 2:31 pm
have to take the whole car , its programmed in the ipc on later cars and is dealer only function at present , did you check the modules page to see if you have pats listed in any of the modules ?
as it is im in the same situation.
you will need 2 keys also if you do it , i would suggest searching on fleabay or similar for a new key and transponder , dont get a cheap china transponder , search on here for the correct one strattech chip is required (someone posted a link for usa people i think in the how to check keys compatability section ) , then go get the blade cut (take your old key as well ) to a store that cuts keys , then goto the dealer , this will save you about $125 in total
also may be worth doing a utube search on programming the remote , or look in the handbook if you got one if your happy to only have one key ,should be something like turn key to on / off 8 times and doors will lock /unlock when in programming mode then press a button on the remote .
B1218:44 Transmitter Identification Code: Data Memory Failure
B1218:51 Transmitter Identification Code: Not Programmed
B1218:81 Transmitter Identification Code: Invalid Serial Data Receive
21/4/19 just out of hospital on heavy medican so dont expend many if any replys ....
LahainaOhana
Post by LahainaOhana » Tue Dec 18, 2018 5:44 am
I got a keyfob and mechanical key on ebay. Dealer programmed it for $65. it works great. Dealer couldn't get the original key to program. I heard someone in the dealership mention "transport mode"??? Now I need to get the keycode to get the new keyblank laser cut. Anyway to extract that info through Forscan?
Andyfocus
Post by Andyfocus » Wed Dec 19, 2018 4:35 pm
just take the other key to a keycut store and get it cut , they will use your working key to copy it and will cost less than a dealer .
