2016 f550 backup camera
angeliquewoodall
Vehicle: 2016 F-550 6.7
Post by angeliquewoodall » Fri Nov 09, 2018 6:27 pm
2016 f-550 sync my touch how to enable the reverse camera? I"ve tried using the numbers off the as built sheets, still no change on screen when put in reverse
twisterrescue
Vehicle: 2003escapeltd
Re: 2016 f550 backup camera
Post by twisterrescue » Sat Nov 10, 2018 6:13 am
what size screen ? 4 inch or 8 inch two totally diff. systems .one uses a 16 pin harness (small screen) big screen is a 56 pin connector .both will need the video + & video - added
angeliquewoodall
Post by angeliquewoodall » Sat Nov 10, 2018 9:25 pm
We have a Bigger Screen
angeliquewoodall
Post by angeliquewoodall » Sat Nov 10, 2018 11:01 pm
sorry that was my wife it is the 8 inch with the big connector I have a adapter cable for the camera
angeliquewoodall
Post by angeliquewoodall » Sun Nov 11, 2018 3:21 am
what does video and video+ mean I am new to this
twisterrescue
Post by twisterrescue » Sun Nov 11, 2018 5:08 am
IF you bought the 56 pin .harness adaptor forget the pin out .I just pin the factory plug (cheap) me I am not at my shop and do not have access to to the lines of (7d020 ) APIM codes they are all the same on sync 2 my ford touch & sync 3 .google add rear camera sync 3 .or monday USA I will find line of code .I do think I posted a little while ago the instructions .look at my post
twisterrescue
Post by twisterrescue » Sun Nov 11, 2018 5:35 am
JUST FOUND apim 7d01 x2xx xxxx xxxx adds camera you now have 7d01 x0xx xxxx xxxx forget warning about checksum
angeliquewoodall
Post by angeliquewoodall » Sun Nov 11, 2018 6:42 pm
that works I did that before my mistake didn't wait long enough when I put in reverse and did a master reboot works thank you!!!!!!!!!!!!
