Anybody using ABS features for brake bleeding?
chrisw
Vehicle: 2013 Ford Fiesta ST180 1.6
Re: Anybody using ABS features for brake bleeding?
Post by chrisw » Sun Dec 30, 2018 3:04 pm
Sorry for not replying sooner. I specifically went for an ELS27 because it stated full support for both MS- and HS-CAN.
There's a good post on here: viewtopic.php?f=4&t=6142
This has a long table of various adapters, compatible protocols etc. The key is having an STN11xx range chipset which has built in support for protocol switching; more details about MS- and HS-CAN switching (or devising your own for an older dongle) are also on the forscan forum: viewtopic.php?t=4
Hello world...
mplieb
Vehicle: Ford F150, 4.6ll, 2002. Ford Taurus, 3l, 2000
Post by mplieb » Sun Dec 30, 2018 4:17 pm
That's great information! Thanks for letting me know about it.
mplieb
Post by mplieb » Sat Jan 05, 2019 12:59 am
I have my new ELM327 Modified adapter, but I still don't see a service procedure for bleeding the abs brakes. Any ideas?
geekwithoutacause
Vehicle: 2014 Ford F250 xlt 6.2 v8
Post by geekwithoutacause » Thu May 16, 2019 8:15 pm
I have an obdmx+ adapter as recommended by forscan but I do not see the abs bleed option anywhere???
What am I doing wrong?
F250 2014
chrisw
Post by chrisw » Thu May 30, 2019 11:48 pm
As @mplieb commented to me via PM (and which I only just saw, apologies again mplieb!) FORScan doesn't yet have ABS bleed implemented for his model vehicle. May be the same for you...
Do you see MSCAN and HSCAN protocols supported in the FORScan Modules page when you're live connected to the vehicle?
Hello world...
Sixty9Boss302
Vehicle: 2013 Ford F-150 3.5L Ecoboost
Post by Sixty9Boss302 » Wed Sep 25, 2019 7:05 pm
Purchased a modified ELM327 to get to MS CAN bus just so I could perform ABS activation for brake bleeding on my 2013 F150 and do not see the option to run the routine anywhere in FORScan. :(
MS CAN bus is working, FORScan prompts to switch from HS to MS during initial read and I can see a few more modules added to the list.
Not sure what vehicle OP has but strange how other 2013 MY Fords seem to have this feature enabled but not working on F150/F250 yet. Curious if it will ever show up in FORScan or what other options there are besides taking to dealer.
@mplieb - what did you end up doing?
mplieb
Post by mplieb » Sat Jan 18, 2020 11:32 am
Sorry for the delay in seeing this.
After contacting the Forscan team directly, they said FORSCAN doesn't necessarily have all modules for all vehicles, and my vehicle (2002 F150 XLT) doesn't support the modified interface. They actually wrote a module for me to use to bleed the brakes using the old interface, and I tested it for them.
faxisis
Vehicle: 2013 Ford Taurus SHO
Post by faxisis » Sat Mar 14, 2020 12:33 am
I'm having an issue with a spongy pedal and done research to find that possibly I have air in the lines, or a stuck open valve in the ABS pump/block. Does anyone know if there is a way to bleed the ABS using Forscan for my 2013 Taurus SHO?
Vehicle: *** Ford ***
Post by f-wolf » Sat Mar 14, 2020 2:19 am
faxisis
Post by faxisis » Mon Mar 16, 2020 6:42 pm
Have a read here: https://www.taurusclub.com/threads/abs ... .285849/
I did read through that thread, and the links inside it. I still see no way to activate any of the ABS valves or pump for my 2013 Taurus using the Forscan software. Am I missing something?
