Can I perform: misfire monitor neutral profile correction?
Nohippychicks
Vehicle: Mustang, Gas 5.0 2012
Post by Nohippychicks » Mon Oct 29, 2018 8:38 pm
2012 Mustang GT, 5.0, manual transmission.
I will need to change the clutch soon, and the service manual calls out performing a "misfire monitor neutral profile correction," after all the labor is done.
I suspect that I can do this with FORScan but it may be called something different in the options.
Has someone here performed this correction?
How can I do it?
Juice
Re: Can I perform: misfire monitor neutral profile correction?
Post by Juice » Tue Oct 30, 2018 2:24 pm
I have not seen that test in Forscan when connected to my '13.
Do you have an SCT tuner? That device has the "crank relearn" function and it WORKS RELIABLY. I've come across some threads on the net that stated even Ford IDS had issues with this function, and you end up with a "crank sensor not learned" fault that won't clear. I ran this test from my SCTX4 when first got the car running, and all went well.
That said, you probably don't "have to" do this procedure, and there won't be any issues after the clutch install.
Nohippychicks
Post by Nohippychicks » Tue Oct 30, 2018 11:49 pm
I don't have an SCT tuner and was hoping to avoid the fiasco of buying one of those units, in favor of FORScan, to keep that extra $400 in my pocket.
Thanks for the help!
Juice
Post by Juice » Wed Oct 31, 2018 1:31 pm
I think you will be fine without doing the reset.
solodogg
Vehicle: 2015 Ford Edge 2.0 Ecoboost
Post by solodogg » Mon Nov 19, 2018 12:53 am
Bringing this back from the dead...
Would love to see this capability added soon. I just had the crank pulley replaced on my 2015 Mustang EcoBoost, and the dealer forgot to perform the relearn. Now when dropping below 3,000rpm, it will sometimes trip a CEL right at 2,965RPM for multiple cylinder misfire, and I sure wish I didn’t have to revisit the dealer to correct it.
abs200
Vehicle: Ford Flex 3.5 Ecoboost
Post by abs200 » Sun Mar 10, 2019 1:13 pm
I agree with this request. I replaced my transmission and installed a new torque converter on my Flex and needed to do this calibration. I ended up having to bring it to the dealer as I was getting misfires on many cylinders before the work was done. No more misfires now that the calibration is complete.
