codes need help?
piperider
Vehicle: 2012 ford focus sel 2.0l
codes need help?
Post by piperider » Fri Sep 14, 2018 1:32 am
Can anyone tell me if this is my keyfob or an issue with the car?My keyfob works when it wants to I tried 2 new batteries same issue.Thanks any help appreciated
Screenshot_20180910-123356_FORScan Lite.jpg (423 KiB) Viewed 515 times
Screenshot_20180907-194721_FORScan Lite.jpg (222.21 KiB) Viewed 515 times
piperider
Re: codes need help?
Post by piperider » Fri Sep 14, 2018 1:34 am
I cant find that specific code B10D7:94-2C
f-wolf
Post by f-wolf » Fri Sep 14, 2018 5:22 am
BODY CONTROL MODULE
Have a look at Page 15 and Page 75 ... look for B10D7:94
Lots of Information here:
http://ww2.justanswer.com/uploads/HE/he ... us_bcm.pdf
piperider
Post by piperider » Fri Sep 14, 2018 12:48 pm
Thank you been trying to find this but couldn't locate any info for this specific code but heres my issue according to this I need to install a new PATS transceiver.Yesterday I had my keyfob tested by a locksmith and they said it wasn't working correctly so could it be just the fob messing up the PATS transceiver or both gone.A new key is 287.00 and id have to go to ebay or the dealer to get a PATS transceiver as theres no used parts in my area
donegal92
Vehicle: ford focus 1.6tdci stage v 110ps
Post by donegal92 » Sat Sep 15, 2018 9:28 am
Normally when a transciever is bad code description is for message missing sounds like key fob do you not have a spare key . Go to bcmi check pats status it tells how many fobs are code and if key in ignition is coded on ford ids forscan should be similar
piperider
Post by piperider » Sat Sep 15, 2018 11:14 am
I only had one key but it was acting up something terrible.Broke down yesterday and bought a new key and everything seems to be working great now
