Sync 3 shutdown splash screen
scott4957
Vehicle: 2017 Ford Fusion 2.7 Ecoboost
Post by scott4957 » Sun Aug 12, 2018 2:05 pm
Hi all. I've located several videos and spread sheets showing how to change the default boot up screen from the ford logo to things like the ST, RS, Mustang etc. I cant find what to change in the APIM module to change the splash screen when you turn off the car. Does anyone know if this has been located? Thanks for any assistance!
Skarcher85
Vehicle: 2018 Ford F-150 XL STX V8 5.0L SuperCrew
Re: Sync 3 shutdown splash screen
Post by Skarcher85 » Mon Aug 13, 2018 4:06 pm
I’m not sure if this can help. But there is a hidden settings access to test your sync 3 module. The skip track “right” button on steering wheel & skip track “right” button on dash are held in at same time. Wait for the speaker test and cancel it. Touch on “test settings” then enable test settings. That will add a test settings access to your settings screen. You can find a video on YouTube on how to access it.
digital.arts
Vehicle: Ford Kuga TDCI 132kw 2017 Facelift
Post by digital.arts » Wed Sep 05, 2018 11:20 am
the changes in this "hidden settings" are NOT permanent, only until the next restart...
This are settings with forscan to change it permanently:
APIM Boot/Shutdown-Screens
7D0-01-02: 0xxx-xxxx-xxxx - for below logos GT,Mustang,Raptor,Ford leave the 0, for ST set a 8
7D0-02-01: xxxx x1xx xxxx - Ford logo start/end
7D0-02-01: xxxx xDxx xxxx - GT logo start/end
7D0-02-01: xxxx xBxx xxxx - ST logo start/end
7D0-02-01: xxxx x6xx xxxx - Mustang logo start/end
7D0-02-01: xxxx x5xx xxxx - Raptor logo start/end
W84IT
Vehicle: 17 fiesta st 1.6 turbo
Post by W84IT » Wed Sep 05, 2018 10:28 pm
mine only shows the st for a second on load up and the ford on shutdown,is that normal?
digital.arts
Post by digital.arts » Thu Sep 06, 2018 5:59 am
just try one of the other screens, maybe GT; this is what i have set.
Do you have the same behavior with GT / Mustang / Raptor ?
