2017 FORD Expedition Trailer Brake Controller Activation
greengecko
Vehicle: Ford Expedition 2017
Post by greengecko » Sat Aug 04, 2018 3:10 am
Screen capture of Selection when FORScan is loading
Vehicle Specification.jpg (28.99 KiB) Viewed 1379 times
Hello need some help if you can assist or point me in the right direction. I have a 2017 FORD Expedition. When I load FORSCan and I select 2017 MY it starts to load the modules correctly but the entire program crashes and shuts down when it gets near the end of detecting the Modules. When I select 2015 or 2016 it completes detecting all the modules and finishes and the program loads correctly. I have installed the Dealer OEM Trailer Brake Controller in the Dash and everything is working with the lights and it detects when I Connect and Disconnect the Trailer but it does not activate the Electronic Brakes on the Trailer and does not allow me to adjust the Gain setting. I am not seeing the settings in the IPC Module as expected to be able to Enable the Trailer Brake Controller and Gain Settings
Successful load when selecting 2015 or 2016 (2017 Crashes program when last 2 modules are being detected)
Successful Load of Modules when Selecting 2015 or 2016.png (434.86 KiB) Viewed 1378 times
Mombo
Vehicle: Expedition, V6, 6600/365, 2017
Re: 2017 FORD Expedition Trailer Brake Controller Activation
Post by Mombo » Fri Aug 10, 2018 2:14 am
FORScan crashes at this point for me too. I didn't think to try an older model.
roylarive
Vehicle: 2017 Expidetion
Post by roylarive » Sat Sep 15, 2018 2:20 am
I loaded Forscan version 2.3.15 and chose sync 2 and it loaded fine. Version 2.3.16 kept crashing. However my trailer brake controller is not showing up in the IPC module. If you find the answer for my issue please let me know.
jchoward1@gmail.com
Vehicle: 2017 Ford expedition 3.6L ecoboost
Post by jchoward1@gmail.com » Mon Mar 18, 2019 7:58 pm
I am having this issue on my 2017 expedition as well. Did you guys find a fix or get your stock break controller working?
Cwalker4213
Vehicle: 2017 Ford Expedition 3.5L Turbocharge
Post by Cwalker4213 » Fri Nov 22, 2019 5:31 am
My trailer brake controller is not showing up in the IPC module. If you find the answer for my issue please let me know. it is showing in the log and it did load. Just can’t enable it. Thanks!
kbsmurph89
Vehicle: 2017 Ford Expedition ecoboost 3.5L
Post by kbsmurph89 » Tue Feb 11, 2020 5:44 pm
Has anyone come up with a fix for this?
Ptrck600
Vehicle: F150/3.5/2016
Post by Ptrck600 » Tue Feb 11, 2020 7:44 pm
Make sure you have the most recent forscan version. Double check your adapter software driver. Looks like there are two changes to be made in the IPC one to enable trailer brake module. The other to enable gain
https://docs.google.com/spreadsheets/d/ ... g/htmlview#
