Remove the chime sound when the door is open and the key is ignition for ford focus se 2.0 2015
flexfuel
Vehicle: ford focus 2.0SE 160hp 2015
Post by flexfuel » Sat Jul 07, 2018 10:13 pm
hello i can't remove chime sound when key is ignition and door is open. I found information: Disables Door Ajar warning chime IPC 720-01-02 xx0x xxxx ( 720-01-02 i dont have this in my car) , 720-02-01 xx*x xxxx xxxx Key In Ignition Warning Chime (to disable, subtract 8 from your current
value there) If it is an A make it a 2, if it's an E make it a 6, etc.-In this method i can't substract 8 because( i have value 1 when i calculate this i have value -7 :lol: ) somebody have different method? this sound make me crazy please help. Best regards
flexfuel
Re: Remove the chime sound when the door is open and the key is ignition for ford focus se 2.0 2015
Post by flexfuel » Sun Jul 08, 2018 10:58 am
Thanks for answer, the first method isn't good, this is not a good solution. About second thing, light switch I have in position 0 this is different thing (lights) . I mean that when I have open driver door and I put key in ignition in position 0 (only put in , not twisted) I have this terrible chime.Please help.
flexfuel
Post by flexfuel » Fri Jul 13, 2018 8:00 pm
Somebody can help ? Please.
