codes can not delete P2585 , P1922
djzapatwork
Vehicle: ford focus mk2 1.6tdci(109hp) 2010year
Post by djzapatwork » Tue Jul 03, 2018 7:25 am
HI friends i have ford focus 2010 1,6tdci(109hp) with dpf and additive tank on
i start the engine and exclamation mark(!) on dashboard light on
i connect laptop with forscan i see P2585 AND P1922.i top up additive tank but it was allready full try to clear codes but the codes when i start the engine after a few second comming up again and exclamation mark(!) on dashboard light on again
any idea what happening?
i did the service for refill the additive tank
f-wolf
Re: codes can not delete P2585 , P1922
Post by f-wolf » Fri Jul 06, 2018 9:40 pm
Just have a look here:
Focus 1.6 Tdci Dpf Fluid Topup - P2585 Code
https://www.fordownersclub.com/forums/t ... 2585-code/
Also:
https://chiptuning.com.au/ford_obdii_error_code_p2585/
djzapatwork
Post by djzapatwork » Wed Jul 11, 2018 12:22 pm
Thanks a lot......nothing i can do the codes can not reset.......i think i will go to ford garage=€€€€€€€£€£€€£££€
lee231
Vehicle: 2006 taurus 3.0 v6
Post by lee231 » Tue Jul 24, 2018 7:00 pm
If you let the the DPF fluid get low and the DTC came on you have to have the dealer reset it.
