2012 Mustang Navigation in Motion
cobrajet_carl
Vehicle: 2012 Ford Escape Hybrid AWD
Re: 2012 Mustang Navigation in Motion
Post by cobrajet_carl » Thu Aug 30, 2018 11:46 pm
Maybe the navigation restrictions are in the ACM settings. I have a 2012 Escape Hybrid which I think has essentially the same navigation radio as a 2012 Mustang. I will be changing the settings in my ACM and I will check if there is anything related to this.
cobrajet_carl
Post by cobrajet_carl » Sun Sep 02, 2018 6:32 pm
Forscan had no info on the ACM settings for my brick nav radio, so I have started trying to decode the AS-Built data to nav radio settings. In your Mustang, can you get the diagnostics screens by pressing and holding down 3 and 6 simultaneously? On my Escape the first line of As-Built data seems to correspond to the settings that show up in the diagnostic screens, excluding the checksums. Nothing jumps out as a driving restriction but there are numerous acronyms that aren't immediately obvious, although most are. I will add some screen grabs to this message when I get a chance.
Picture is just a few lines of data, 0010 0001 0100 0000 1001 0000 1011 0010 etc which matches the first line of the as-built data of 2140 90B2. A few parameters are unknown and might be related to driving restrictions.
So I'm wondering what RPA, HOV, FES and RSEM are as these are not obvious to me what they mean. OK so FES means Family Entertainment System and RSEM means Rear Seat Entertainment Module so those are out.
mturner
Vehicle: Mustang 5.0 2012
Post by mturner » Sat Sep 15, 2018 1:26 am
Carl,
I will see if I can get into the diagnostics screen and get back to you. Thanks for everyones effort in trying to figure this out.
Michael
mturner
Post by mturner » Sat Oct 13, 2018 12:15 am
Still looking for answers on this one. I have tried everything I can think of.
Michael
lenko
Post by lenko » Sat Oct 13, 2018 11:07 pm
Here's a 2011-2014 Ford F 150. See what you can glean out of that.
https://docs.google.com/spreadsheets/d/ ... 1329872825
lenko
Post by lenko » Sat Oct 13, 2018 11:28 pm
Here's another: https://docs.google.com/spreadsheets/d/ ... DJfA#gid=0
In your first post you said you enabled this in Forscan - Did you change that back? It seems the original first four codes should be either 5355 in US or 4341 in Canada. Then you change to second number to 7. What version of sync do you have exactly?
mturner
Post by mturner » Mon Oct 29, 2018 3:14 am
I have sync version 1. My original number was 0155. I did try 0755, but it did not work. Seems like someone would have done this by now on a 2012 Mustang. Maybe it is not possible. Anyone?
Thanks, Michael
mturner
Post by mturner » Mon Oct 29, 2018 3:18 am
Here is all of my as-built data.
PCM 1 FFFF FFFF 020F
PCM 2 E40C 9AFF FE99
PCM 3 FFFF 03FF 1F32
PCM 4 FFFF FFFF FF0F
PCM 5 FFFF FFFF FF10
PCM 6 FFFF FFFF FF11
PCM 7 FFFF FFFF FF12
PCM 8 FFFF FFFF FF13
PCM 9 FFFF FFFF FF14
BCE Modules
Module Address Instructions
Body Control Module B
BCMB 7B7-01-01 1062 4480 F6
BCMB 7B7-02-01 0300 0000 C4
BCMB 7B7-03-01 0100 0000 C3
BCMB 7B7-04-01 8500 0000 48
BCMB 7B7-05-01 253A 0C00 2F
BCMB 7B7-06-01 6400 0000 29
BCMB 7B7-07-01 1101 0101 DA
Accessory Protocol Interface Module
APIM 7D0-01-01 0004 4000 001D
APIM 7D0-02-01 0155 5300 0083
APIM 7D0-03-01 0000 0000 00DB
Instrument Cluster Module
ICM 720-01-01 E388 FF61 F4
ICM 720-02-01 FA00 0000 24
Generic Electronic Module
GEM 726-01-01 4A0A 83
GEM 726-02-01 03C0 2020 0033
GEM 726-03-01 0140 72
GEM 726-04-01 0A3C
GEM 726-05-01 040C 43
GEM 726-06-01 0000 34
GEM 726-07-01 2505 5F
GEM 726-08-01 1305 0A58
GEM 726-09-01 C000 F7
GEM 726-10-01 8008 0000 00C6
GEM 726-10-02 0000 0000 003F
GEM 726-10-03 0000 0000 0040
GEM 726-10-04 0000 41
GEM 726-11-01 1400 53
Audio Control Module
ACM 727-01-01 2140 8C29 80C6
ACM 727-01-02 0888 C081
ACM 727-02-01 2E5F
ACM 727-03-01 1446
ACM 727-04-01 0000 2D0C 1F8B
ACM 727-04-02 062D 67
ACM 727-05-01 1145
ACM 727-06-01 0D42
ACM 727-07-01 0007 2F57 5B1E
ACM 727-07-02 76AD
ACM 727-08-01 000A 3335 5C05
ACM 727-08-02 649C
ACM 727-09-01 000A 3335 5C06
ACM 727-09-02 649D
ACM 727-10-01 080E 3C01 16A8
ACM 727-10-02 1F01 161F 4BE0
ACM 727-10-03 090D 090D 329F
ACM 727-10-04 7308 0ECB
Power Steering Control Module
PSCM 730-01-01 013A
Restraint Control Module
RCM 737-01-01 315A 5642 50B3
RCM 737-01-02 3843 4636 437B
RCM 737-01-03 3532 3138 3244
RCM 737-01-04 3339 AF
RCM 737-02-01 C700 0000 08
Anti-Lock Bake System Module
ABS 760-01-01 016A
