05 Mustang Cluster Upgrade
chiefgeek
Vehicle: 2015 Ford F250 SD 6.7L
Post by chiefgeek » Sun Jul 01, 2018 2:10 pm
I have an 05 mustang 120mph non-myColor cluster and I have been looking for a myColor to replace it and was wondering if you know of any reason that a newer year 07 in particular cluster will work in the 05 (lkqonline says they don't interchange).
The other question relates to speedo, mine goes to 120 but most of the ones I see online go to 140, can I put the 140 in and tweak some settings in module to get it to function?
For Reference I found this as built data for 05 mustangs:
HEC 720-01-01 2023 0000 006C # 05 120mph non-myColor
HEC 720-01-01 2003 0000 004C # 05 120mph myColor
HEC 720-01-01 2003 0000 004C # 05 140mpy myColor - seems to be identical to 120mph cluster
chiefgeek
Re: 05 Mustang Cluster Upgrade
Post by chiefgeek » Sat Sep 15, 2018 3:15 pm
For anyone contemplating the upgrade, I finally did it and have had no problems at all. Only problem I had was on first key on, I saw a TPMS fault in the DIC. I just used the as built data from my cluster and TPMS fault is gone.
