SCCM not showing
valkman
Vehicle: 2013 Ford Focus ST
SCCM not showing
Post by valkman » Fri Jun 29, 2018 12:31 pm
hey guys.
I have been looking for an answer for this for the last 4 days, but I cant find any
I have a 2013 ford focus ST, and I want to be change the number of the turn signals flashing when "tapping" the turn signal lever.
I was able to find out that it can be changed under the SCCM (stearing column control module) option
but for the life of me, when I connect to forscan (lastest version) with the MS/HS ELM connector, that module does not show up at all in the list
I tried different usb ports, nothing, disconnect and reconnect, nothing, reboot the laptop, nothing
so I am sure there is a way to get that SCCM to show up
any help is greatly appreciated
thanks
JboyJohnny
Vehicle: F150,5.0,2015
Re: SCCM not showing
Post by JboyJohnny » Wed Jul 04, 2018 6:42 pm
2015 5.0 XLT Sync 2
Im having the same issue.
Does anyone have any ideas?
JboyJohnny
Post by JboyJohnny » Wed Jul 04, 2018 7:39 pm
Ok so I figured it out.
I hope your adapter has the MS/HS switch, if not this is probably of no value to you.
Go into forscan.
Go to settings and make sure under ELM327 specific that the HS/MS switch option is selected.
Also if it asks you to load your profile select no.
I could type a million words explaining how to do it but if you watch the first 3 mins of this video youll see exactly what to do to make all those modules appear.
https://www.youtube.com/watch?v=IhhF7iNAEAg
I hope this helps!
valkman
Post by valkman » Mon Jul 09, 2018 4:48 pm
not showing still
enabled hs/ms under connection (not auto)
not showing sccm
something is blocking this module form showing. If I can just know what it is.
I know its not a setting setting in forscan, otherwise it would have showed by now
I have been trying this for a whole week now, and nothing..
anyone came across this and fixed it?
thanks
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Mon Jul 09, 2018 6:35 pm
Has it actually got one?
valkman
Post by valkman » Wed Jul 11, 2018 8:05 pm
i am wondering the same...
i mean there has to be a way to change the number of blinks when you tap the turn signal lever.
if sccm is not there, how else to change the number? for a 2013 focus st?
able03
Vehicle: f150,5.0L,2017
Post by able03 » Wed Jul 03, 2019 12:15 am
Make sure you are running the latest version of forscan.
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley » Wed Jul 03, 2019 2:59 pm
2013 Focus probably does not have SCCM module. Changing the number of turn signal blinks may not be possible for this vehicle because most changes must be done in Central Configuration.
Don Ridley
Post by Don Ridley » Thu Jul 04, 2019 10:50 pm
Check the as built data on the Mototcraft website for a sccm module.
