ELM not found
Rick1342
Vehicle: Ford F150 gas 385 hp 2017
ELM not found
Post by Rick1342 » Wed Jun 13, 2018 8:53 pm
I downloaded forscan generated and loaded a licence. The program will not connect. I keep getting no ELM found. Does anyone have any ideas on how to get this working?
f-wolf
Re: ELM not found
Post by f-wolf » Thu Jun 14, 2018 12:54 am
You may have to make some changes here ??
ForScan ......jpg (41.97 KiB) Viewed 576 times
tommyboy5740
Vehicle: 2013 Ford Taurus PI sedan
Re: ELM not found
Post by tommyboy5740 » Thu Jul 12, 2018 1:50 am
Had the same problem with my scanner tool. I found that if I unplugged the unit(scanner tool) turned off the key in the ignition, then turned on the key to run(not start) plug in the scanner tool, press the reset button on front till power light is solid and release finger from button, bluetooth light will blink quickly, then go to the laptop, open FORscan, connect...it should work to see the vehicles records/status etc. Try it and let me know if that works.
