FORScan in Ubuntu Linux 18.04
Bigelow1984
Vehicle: F250, 6.4L Diesel, 2008
Post by Bigelow1984 » Tue Jun 12, 2018 6:07 pm
Hi all,
I became aware of FORScan a few weeks back. After reading up on it a bit, I downloaded FORScan version 2.3.15 beta for Windows and loaded it into my Ubuntu 18.04 laptop. I installed it with wine. It runs great in standard license mode. FORScan connects to my truck and reads everything fine.
But, the extended license will not work. The extended license key info is correctly loaded into the wine WIndows system.reg file. But, something isn't allowing the extended license to load into the FORScan program when it is started up. My system time/date are correct, and I verified that wine is reporting the system time correctly. I've run out of ideas as to why it isn't working. I read that there is a "wine version" of FORScan that doesn't have extended license function. I didn't download that, ( I didn't even see it as a download option ). I'm using FORScan version 2.3.15 beta for Windows.
Any recommendations as to what I can do next to get this to run with the extended license in Ubuntu 18.04 with wine?
Bigelow1984
Re: FORScan in Ubuntu Linux 18.04
Post by Bigelow1984 » Wed Jun 13, 2018 12:48 am
Well, I've been working on this all day, and I'm starting to think it's just not possible to run FORScan with the Extended License in wine/Linux. Can someone please confirm if it is actually possible. I know the Windows wine version wouldn't do it. But, I thought the newest version for WIndows had wine support for the Extended License. Am I misunderstanding?
Vehicle: *** Ford ***
Post by f-wolf » Wed Jun 13, 2018 1:37 am
Comparsion of FORScan applications
http://forscan.org/comparsion.html
twin--turbo
Vehicle: Transit 2.4 100 2007
Post by twin--turbo » Tue Jun 19, 2018 11:11 pm
Tried tonight on my Linux "Mint" and the code goes into the registry but is not loading.
So yeah does not work.
May see if I can pass through USB in virtual box to a my windows7 "VM"
TT
nick.theboatman
Vehicle: Fusion TDCi 1.4 2006
Post by nick.theboatman » Fri Jun 22, 2018 8:05 pm
Id love the opportunity to try to port to proper Linux....
luisjr777
Vehicle: lincoln town car 8cyl 2003
Re: FORScan in Kubuntu Linux 18.04
Post by luisjr777 » Sat Jul 11, 2020 6:59 pm
I was able to use Forscan on Kubuntu.
Steps:
1. Install PlayOnLinux from software center.
2. Install Forscan for windows using PlayOnLinux.
Forscan will be in the list of programs to run inside PlayOnLinux.
2. Download USB driver CH340 from: https://cdn.sparkfun.com/assets/learn_t ... _LINUX.ZIP. Install it using wine.
4. From website: https://samhobbs.co.uk/2015/04/scantool ... ware-linux
Install scantool using terminal:
sudo apt-get update
sudo apt-get install scantool
sudo usermod -a -G dialout YourLinuxUserName
5. Plug the ELM327 Adapter into laptop.
6. Run PlayOnLinux
7. Run Forscan
Forscan will popup a window telling you to make sure key is in the on position.
Hit Ok. You don't need to be connected to car to setup adapter on laptop.
8. Look at the lights on the adapter, they should be blinking yellow lights.
9. Success!
Now that you have a good connection from pc to adapter, you can plug it into the car and have some fun!
