Sync 3 theme and splash screen ST
cwagener
Vehicle: Ford Focus Ecoboost
Post by cwagener » Fri Jun 08, 2018 6:09 pm
Hello guys,
I've tryed to change my normal Ford theme and splash screen to the ST theme and splash screen but unfortunately it doesn't work poparly. I've already searched for a similar post and I've already searched for a solution in the worl wide web but I can't find the correct DID for the ST theme. I've now the ST start logo, the Ford classic theme but with a Ford logo at the end. Has anybody an idea what exactly has to be changed so that I've the ST start logo, the ST or classic theme and the ST logo at the end?
As I understood I've to change the following data:
7D0-03-01 xxxx xXxx xxxx
7D0-01-02-Xxxx xxxx xxxx
Is this correct, is this correct?
And which number I've to insert to change as above mentioned?
Vehicle: Ford Focus 1.5l Ecoboost Titanium, Sync 3
For you help, many thanks in advance.
ThomasD1962
Vehicle: Ford C-max 1.0 125ps '17
Re: Sync 3 theme and splash screen ST
Post by ThomasD1962 » Sat Aug 04, 2018 7:40 am
There are five themes (as I understand it); Timeless (which is standard), Classic (same but more colors), GT, Lincoln Timeless and Lincoln Next.
ST doesn't have it's own theme, just the start and end screens.
And here are the numbers!
7D0-03-01: xxxx 00xx xxxx - Ford Classics theme
7D0-03-01: xxxx 01xx xxxx - Ford Timeless (default)
7D0-03-01: xxxx 04xx xxxx - Ford GT performance
For the Lincoln theme’s first do 7D0-01-02: 8xxx xxxx xxxx
7D0-03-01: xxxx 02xx xxxx - Lincoln Timeless (Gold Theme, Black Icons)
7D0-03-01: xxxx 03xx xxxx - Lincoln Next (Gold Theme, White Icons)
Splash screens:
7D0-02-01:
Standard Ford logo; XXXX 0106 XXXX
Lincoln logo; XXXX 0401 XXXX
Lincoln Black Label logo; XXXX 0301 XXXX
Ford Raptor logo; XXXX 0501 XXXX
Ford Mustang logo; XXXX 0601 XXXX
Ford GT350 logo; XXXX 0701 XXXX
Vignale Classic; XXXX 0801 XXXX
Ford GT350R logo; XXXX 0901 XXXX
Ford Performance ST logo; XXXX 0B01 XXXX
Ford Performance RS logo; XXXX 0C01 XXXX
Ford Performance GT logo; XXXX 0D01 XXXX
Lincoln Continental logo; XXXX 0E01 XXXX
You're welcome!
cwagener
Post by cwagener » Thu Aug 09, 2018 10:34 pm
Many thanks ;)
Traina
Vehicle: F150, 3.5eb,2017
Post by Traina » Fri Sep 21, 2018 12:27 pm
Great information, are these value changes the same for a 2017 F150?
Miklelord
Vehicle: Ford Focus 3 Hatchback, 1.0, 2013
Post by Miklelord » Sun May 26, 2019 8:26 pm
But ST "end logo" is not shown on my Focus after these changes, just the start logo.
Do you have any advice?
mictei
Vehicle: KUGA 2017 179HP 2.0TDCI
Post by mictei » Tue May 28, 2019 5:27 pm
the ST logo will only be shown on the Theme Ford Timeless when quitting.
All other settings will cause the Ford logo to appear when exiting.
I have never (since 2 years) found a solution.
Dustangel999
Vehicle: Mondeo St line mk5 Turnier 2018 2.0
Post by Dustangel999 » Sun Jun 09, 2019 1:21 pm
Ich hab es auch schon probiert. Ich wollte Lincoln Theme mit St Performance Splash Screen vereinigen. Weder das eine geht oder das andere geht, zusammen geht es nicht. Bei den anderen Themen geht es beim anschalten das ST Logo und beim abschalten kommt das Ford Logo.
fcaputo4
Vehicle: 2016 Mustang GT, V8
Post by fcaputo4 » Wed Jul 24, 2019 12:37 pm
I just installed sync 3 v3.0 build 19149 and noticed that the GT Performance theme and splash screen has been removed. It does not show up in the test setting either. Anyone have a clue as to why that would be? Something minor but I did enjoy that theme before updating.
ThomasD1962
Post by ThomasD1962 » Tue Sep 10, 2019 5:24 pm
I also miss my GT theme! :cry: I would also like to have the new Lincoln Corsair or Nautilus themes! :P
FiestaST2018
Vehicle: Fiesta 2018
Post by FiestaST2018 » Wed Sep 11, 2019 5:27 pm
Splash screens:
7D0-02-01:
You're welcome!
Alguém tem estes códigos para os novos Fiestas Mk8, funcionar as led como mínimos (luzes baixa) junto com as luzes de médios (headlights)
Does anyone have these codes for the new Fiestas Mk8, working as minimum led (low lights) along with low beam (headlights)
