13-14 Mustang 5.0 TPMS
hennecyt
Vehicle: 2014 Mustang GT 5.0 420whp
Post by hennecyt » Fri Jun 08, 2018 12:52 pm
New user and i need some help. I've been searching the forums and looking at spreadsheets for other years but i cant find a answer on how to disable the tpms light. If anyone could tell me which module to go in and what to change that would be greatly appreciated. I tried changing values myself but it didnt have any change. Also if anyone knows how to disable the airbag light i could use the help with that too. Thank you in advance!
LaForge
Vehicle: Ford Mustang GT 2006 4.6l 350HP
Re: 13-14 Mustang 5.0 TPMS
Post by LaForge » Sat Jun 09, 2018 8:28 am
Dear friend,
You’ll find the answer in the ic module.
Regrettably I have a 06 mustang, so I don’t know the exact address
But you can carefully try one after the other Bit.
Nothing will be damaged.
If you have it, please tell us the needed bit which controls the tpms message and light.
Best regards
Karsten
riding da Black Pearl II
TPMS De/Activate Service *
DRL De/Activate Service *
Chimes De/Activate Service*
FogLamps De/Activate Service* x1
X1 = in progress. Final solution not found until now
* on 05-09 Mustangs
hennecyt
Post by hennecyt » Sat Jun 09, 2018 2:32 pm
LaForge thanks for the advice! I’ll try that and post what I find.
LaForge
Post by LaForge » Sun Jun 10, 2018 6:37 am
A friend of mine told me it is bit 7 in byte 1
720-01-01 XXXXXX1X XXXXXXXX 1=Tpms on 0=Tpms off
Best regards
Karsten
* on 05-09 Mustangs
Lx90coupe
Vehicle: Mustang 5.0 2013
Post by Lx90coupe » Sat Oct 13, 2018 6:13 pm
726-02-01.
0000 0000 xxxx disabled
03C0 2323 xxxx enabled
lenko
Post by lenko » Sat Oct 13, 2018 10:33 pm
In the 2012 Ford F150 turning TPMS off/on was Body Control Module 726-22-01
x0xx xxxx xxxx Off.
x1xx xxxx xxxx On.
That covered the 2011-2014 F 150s. https://docs.google.com/spreadsheets/d/ ... 1329872825
incubus2432
Vehicle: 2013 Mustang Boss 302 5.0 444hp
Post by incubus2432 » Thu Oct 18, 2018 2:08 pm
726-02-01.
Worked like a charm. Thanks much!
