Ford fusion 2015 DTC B1218
steell555
Vehicle: Ford fusion model 2015
Post by steell555 » Sun May 27, 2018 11:52 am
While checking errors, I received information DTC B1218:00-0A "Transmitter identification code" . DTC can be reset but after switching the ignition, it reappears. I checked both owned keys. Previously disconnected the battery maybe this is the reason?
steell555
Re: Ford fusion 2015 DTC B1218
Post by steell555 » Tue May 29, 2018 10:33 am
Maybe this is a problem in the ignition system? 1.5 EB engine
steell555
Post by steell555 » Tue May 29, 2018 12:35 pm
steell
Vehicle: fusion se 1,5
Post by steell » Fri Jun 01, 2018 2:09 pm
What is this error B1218?
Vehicle: *** Ford ***
Post by f-wolf » Sat Jun 02, 2018 10:22 pm
Open this File ... do a word search for B1218
Starts on Page 3
viewfile4eea-2.pdf
(311.8 KiB) Downloaded 313 times
You ' may ' have to reprogram your keys ???
steell
Post by steell » Sun Jun 03, 2018 3:44 pm
Thank you, I've already read it. All keys work correctly. If I did not check Forscan, I would not know that I have a mistake. I disconnected the batteries, maybe it caused a problem? I will not do it with Forscan, so far the lack of this possibility.
steell
Post by steell » Thu Jul 12, 2018 9:21 am
The problem is not resolved, the error DTC is still there, I do not see any other symptoms.
Post by f-wolf » Fri Jul 13, 2018 12:40 am
See if this will help you:
DTC B1218.jpg (155.85 KiB) Viewed 2509 times
viewfile4eea-2 (1).pdf
(311.8 KiB) Downloaded 160 times
steell
Post by steell » Sun Jul 29, 2018 9:41 pm
I read but there is no answer to my problem, the DTC described are different. Both my keys are working properly. I do not have more pre-programmed keys than the two I have.
