Hello everybody.
I've done a 4' to 8 inch screen upgrade, and everything is working except for the backup camera settings.
When the setting for camera delay is set to on, the camera won't turn off again when i start driving forward again. I can only turn it off by switching the ignition to off.
Anyone had a similar problem?
Camera delay is not working
- Vehicle: Ford Fiesta 1.0 Ecoboost
- Vehicle: 2013 Ford Focus/ 2.0L/Automatic
Re: Camera delay is not working
I don't have an answer, but how do you set the delay? I added the camera option to my 2013 Focus SE. The delay option is set automatically, but it only shows a blue screen when shifting back to drive.
It's because you camera is powered by your reverse light and not a live by the ignition.
The camera needs to be powered on when ignirion is on.
does this effect active guidelines too..fiestaecoboost wrote: ↑Thu May 24, 2018 4:18 amIt's because you camera is powered by your reverse light and not a live by the ignition.
