Fiesta mk8 compatibility
BiruFoFi
Vehicle: Ford Fiesta 1.5 TDCI 85cv 2018
Post by BiruFoFi » Mon Apr 09, 2018 10:17 am
Is ForScan compatible with the latest Fiesta mk8?
rsford2012
Vehicle: ford focus st
Re: Fiesta mk8 compatibility
Post by rsford2012 » Sat Jun 09, 2018 4:57 pm
i have just tried to deactivate my Start/Stop... Somehow i can read all data, but when im trying to change them im getting a system error.
Coding the APIM-Module was no problem for me.
I have no idea if i did something wrong or the software isnt supporting the new Fiesta Active 1.0 85hp PCM Module?
arisgardelis
Vehicle: Ford Fiesta Vignale 1.5 TDCi
Post by arisgardelis » Tue Jun 12, 2018 11:02 pm
I have a Fiesta MK8 1.5TDCi Vignale with B&O sound system. I added the sync3 climate soft and voice controls, but it does deactivate the surround sound. Since music is more important to me, I returned it back to factory setting. I think I also tried to deactivate Start/Stop, but I got an error. The setting was picked up from the F150 settings spreadsheet. It seems that many settings change by themselves if you change another, so be careful and always keep your factory as built settings.
roylion15
Vehicle: Fiesta ST, 1500, Ecoboost, 200 PK, 2019 model
Post by roylion15 » Sun Dec 09, 2018 3:57 pm
Same problem here
I can read / write APIMs modules Asbuilt and other config (sync 3) with none problems ..; adding some values for climate screen and no problems.
I can read all others modules, but can't write any modifications in some modules like the IPC by example.
It gives an error when writing a xx % and thus the message "the diagnostic procedure was interrupted"
EU Fiesta ST 2019 model.
No support in PM without invitation, please !
O. Van der Enden
Vehicle: Ford fiesta 2009 1.6 tivct
Post by O. Van der Enden » Sat Jan 12, 2019 1:17 pm
still have the same problem here, cant get any modules like the ipc programmed, same error
Carstenth
Vehicle: Focus MK 3.5 2016 1.0
Post by Carstenth » Wed Feb 20, 2019 11:24 am
Try the new version of forscan they say that they fixed the problem with IPC
stetta93
Vehicle: Ford Fiesta MK8 1.5 120cv
Post by stetta93 » Mon Mar 04, 2019 9:19 am
Same problem here.
With the latest version of Forscan i can't write on IPC, the problem wasn't solved.
