2014 Fusion Pats Programming?
jackofalltrade
Vehicle: 2006 lincoln navigator 5.4 3v
Post by jackofalltrade » Mon Apr 02, 2018 2:09 am
Hello All,
Love the site and member's. One question, is Pats supported on the 2014 Ford Fusion 1.5L?
I have looked at all modules and cannot find it. Can someone confirm? it is or not.
twisterrescue
Vehicle: 2003escapeltd
Re: 2014 Fusion Pats Programming?
Post by twisterrescue » Tue Apr 03, 2018 12:27 am
the new 128 bit ford flip keys do not program the normal pats way .I work at a ford dealer they need IDS or the new FDRS they go live to ford tech site they also program in 20 seconds . But if you have 2 keys that run car turn key A to run for 8 seconds turn off take key B turn to run for 8 seconds turn off stick key C in turn to run 8 seconds cluster will say key program good .If you have only one key you will need dealer programming buy the way these Keys cost 198.00 plus 20.00 to cut key 20,000.00 key machine I use international key supply in New York good folks about 60.00 for key most dealers charge 1 hour labor to program keys with IDS or FDRS
jackofalltrade
Post by jackofalltrade » Wed Apr 04, 2018 2:36 am
Thanks for the reply,
I am rebuilding the car which did not come with keys from the auction so it seems like I will have to take the car
to the stealership.
