Albert
Vehicle: F350 7.3 turbo 1999
Post by Albert »
I've had this product two weeks got nothing on screen I purchased elm 327 and my laptop say's no connection even though the The 327 lights up the disk I received was shattered with no reply from the company I bought it from contacted the forscam company and no response either it seems both companies feel it is necessary to rape one of many customers anyone have a idea what to do
Andy-
Vehicle: Ford Focus Petrol 1600 2005
Post by Andy- »
Mine was the same until I loaded the correct driver into laptop, it worked fine after that.
maxford01
Vehicle: 2002 ford falcon AU3 4.0l I6
Post by maxford01 »
Johnny641 wrote:
Tue Jul 17, 2018 2:58 am
I will choose this adapter for my F-150 xlt 2015 3.5 EB, i guess that will be fully compatible with Forscan and my truck?
https://www.amazon.com/VINT-TT55502-ELM ... B01N18TOFB
Tell me if i'm wrong
Johnny641
Will this adapter work on an Australian ford falcon au series 3? Thanks
mquick5
Vehicle: 2017 Ford Expedition Xlt El 3.5l turbo*2006 Roush
Post by mquick5 »
maxford01 wrote:
Mon Nov 05, 2018 2:34 am
Johnny641
If you ship the car over to me, I'll let you know! lol j/k but i have no idea really, but dont see why not. And the price is worth the gamble. Mine works fine here in the USA,
tolisz78
Vehicle: ford fiesta mk7 titanium
Post by tolisz78 »
Hi to all. I found this adapter to buy
.https://www.ebay.co.uk/itm/ELM327-USB-m ... rk:37:pf:0
I have bought 1 other so far but it wont let me to write to ecu when i make a change, Can someone please tell me if this is the wright one?? it has the chip ft232rl i think.. sorry for my english. I will use it to a fiesta mk7 2010 model 1.4 petrol..
rdeage
Vehicle: Ford Edge, 4 cylinder eco-boost, 2015
Post by rdeage »
I can't find an ELM327 adapter that will connect with my 2015 Edge. Bought two different USB OBDII with HS/MS CAN. One connected once and was able to eliminate the hated double honk, but then couldn't find the ELM after that. DOES ANYONE HAVE AN EDGE AND KNOW OF AN ADAPTER THAT WILL WORK? PLEASE!
Andyfocus
Post by Andyfocus »
if it connected once then it should connect all the time , have you tryied a different laptop/pc , making sure the hs/ms switch is in the hs position when first connecting ? , not loading the profile ( if you saved one ) and let it detect the modules again ? .
rdeage
Post by rdeage »
I know, doesn't make sense. Once it connected, I thought I was home free. Have not tried a different laptop. Guess that is next, will install Forscan on another laptop and see what happens. Not sure now to determine the hs/ms switch setting. Not labeled, Tried to connect in both positions.
Tim1427
Vehicle: Galaxy Mk3
Post by Tim1427 »
I bought a ELM 327 500k on ebay with high and medium switch over which was so say configured for FORScan. When you plug in the adaptor and link to your PC and use the FORScan programme to connect and it should link or tell you the switch is in the wrong position to connect and scan.
It works on windows 10 for me and my Galaxy Mk 3.
Your need the extended licence to be able to programme things like key fobs etc.
I`m still trying out the more difficult items but have been able to sort out a static regen of the particulate filter after some sensor issues.
Kind regards Tim1427
ke4clu
Vehicle: 2013 f150 STX
Post by ke4clu »
I chose this adapter and it works flawlessly with Windows 10.
https://www.ebay.com/itm/Forscan-ELM327 ... 2749.l2649
