Racecar modifications.... Help please
jamesaikens
Vehicle: Ford Mustang 2016 GT
Post by jamesaikens » Wed Feb 28, 2018 4:13 pm
2014 Mustang, being turned into a race car. Removed the factory seats to install carbon fiber seats. Airbag light of course is on, but I also notice a TON of codes for the seatbelts... as they are missing now.... and have been replaced with 5 point harnesses. Does anyone know what to modify in the asbiult to tell the car it doesn't have seat belts or airbags? Ford offers a control pack for stand alone race cars, that are Coyote driven and use the factory IPC... in those scenarios, there are no airbag lights or seat belt minders. Considering that information.... these fields live somewhere in Forscan, but WHERE?!
Also, changed 726-02-01 (GEM) to 0380 2020 00F9 from 03C0 2020 0033 allegedly to disable TPMS, but I still get a low pressure warning on the IPC :(
James Aikens
(West Palm Beach, FL)
Juice
Re: Racecar modifications.... Help please
Post by Juice » Wed Feb 28, 2018 4:31 pm
I'm taking a guess at this, based on facts that I've learned about this platform.
Get rid of the RCM module. The PCM won't care if a module is missing. But as long as the RCM is installed in the car, you will have the "christmas tree" dash. (bunch of lights on)
If you still have issues, have your tuner give you the Coyote Control Pack tune and work off that.
Juice
Post by Juice » Thu Mar 01, 2018 1:18 pm
Oh yea, You may also need to modify IC (cluster) settings to turn off warning light(s) after removing the RCM.
I did a cluster swap on mine, and the cluster came from a car with ABS and Traction control. These lights were on because my car has neither, as I have NO ABS.
BIG ANGRY HILLBILLY
Vehicle: 08 F350 6.4/600HP
Post by BIG ANGRY HILLBILLY » Sun Mar 04, 2018 8:31 pm
Im not aware of a controls pack that has a Ford instrument cluster.
If there is, post a part number here and I can likely get you the asbuilt for it, to shut the lights off in the cluster.
You can trial and error turn one bit to 0 at a time to see if it kills the ABS or SRS lights, I have figured out lots of weird shit on Ford modules doing it this way.
BIG ANGRY HILLBILLY
Post by BIG ANGRY HILLBILLY » Sun Mar 04, 2018 8:33 pm
ALSO worth noting.
There's airbag/pretensioner "simulators" that are used as a diagnostic tool, which plugs in where an airbag or pretensioner was, that has the same resistance and simulates the load of an airbag, and turns the light out.
Would be cheaper and neater than cobbling the stuff under the dash somewhere.
DO NOT EVER MEASURE THE RESISTANCE OF A PRETENSIONER OR AN AIRBAG WITH A MULTIMETER IN AN ATTEMPT TO BUILD YOUR OWN SIMULATORS.
Juice
Post by Juice » Mon Mar 19, 2018 4:01 pm
jamesaikens wrote:2014 Mustang, being turned into a race car.........Ford offers a control pack for stand alone race cars, that are Coyote driven and use the factory IPC... in those scenarios, there are no airbag lights or seat belt minders. Considering that information.... these fields live somewhere in Forscan, but WHERE?!
James Aikens
You need to modify the IPC as built also. I found everything on the first line of the IPC as built on mine, 720-01-01 I think it was in. Turned off ABS & traction control lights. I disabled TPMS in the GEM/SJB (I have multiple sets of wheels :D ), and the TPMS light still "proofs" on startup and stays off while driving. So when PA starts to enforce working TPMS for safety inspections, I should pass with flying colors. :lol:
Levi9339
Vehicle: 2014 mustang
Post by Levi9339 » Wed Nov 21, 2018 3:52 am
Did you ever figure out away to turn off the RCM? Having issues with mine currently pulling timing from the motor because of the yaw rate sensor.
PeterPogo
Vehicle: Mustang, 3.7L V6, 2012
Post by PeterPogo » Sat Dec 15, 2018 6:28 pm
Any update on the TPMS issue?
PeterPogo
Post by PeterPogo » Sun Dec 30, 2018 11:08 pm
Bump on the TPMS issue, did you ever figure this one out? Thanks
PeterPogo
Post by PeterPogo » Sun Jan 06, 2019 12:50 am
726-02-01. GEM Module
Originally: 03C0 2020 0033
xx8x xxxx xxxx disabled
xxCx xxxx xxxx enabled
Doing this disabled the TPMS light/message on a 2012 Mustang Premium V6, 3.7L w/ sync. After driving ~120 miles with speeds between 0-110 MPH, the TPMS light is still off after the above modification. Seems like it works.
