Region And Language for APIM and IPC
Saif
Vehicle: Ford f150 2018 ecpost 6 cylander
Re: Region And Language for APIM and IPC
Post by Saif »
I hove Sunc. 3 idownload the niv from https://cyanlabs.net/ford-focus-asbuilt-database/
Update the sunc to 3.4
Language work great now 5341. i remove Sirius but niv stll not working fault.
omar302
Post by omar302 »
I don't know what to say. I really don't have experience in this.
Did you you have NAV originally? Sync3 cannot add nav because of hardware difference.
What is the error code you get?
Did you try to do Mater Reset?
Saif
Post by Saif »
Yes its i have navigation but win i change the map it show niv fault all time i restart vehicle. I think its region cant program another contery map. Any way now i used car play map and i program niv to disable. If i find somthing to do i will notice. Thanks for you reply and help.
omar302
Post by omar302 »
Saif wrote:
Mon May 25, 2020 8:32 am
I couldn't find anything on how to successfully change the maps region. Maybe it is related to the VIN number stored in the APIM? Your VIN is for a Non-GCC vehicle, maybe changing the VIN on your APIM to a VIN from a GCC vehicle with Sync3 and NAV could help?
Saif
Post by Saif »
Ist possible to do it how can i make change the vin in apim....
tranminhduong
Vehicle: ford, ranger,3.2,2017
Post by tranminhduong »
gregsm888 wrote:
Wed Jan 30, 2019 8:15 pm
Hello
How can I change language in older cars (Explorer, C-Max Energi) with two LCD speedometer? Contry code is missing there
I would like to ask for the code for the country of Vietnam. Do you have one and instructions for filling it out
egozo
Vehicle: Ford fusion 2018 SE
Post by egozo »
Может кто с русским сможет помочь на фьюжн 2017 с шайбой? Смена на 5253, 5255 не помогает
И все таки, как верно: RU или RS?
kalongauto
Vehicle: mazda ,ford
Post by kalongauto »
What is the code in Vietnam, please help me.
Thank you very much !
Ptrck600
Vehicle: F150/3.5/2016
Post by Ptrck600 »
Vietnam code 564E
Natura
Vehicle: Ford Kuga 2019
Post by Natura »
Do you think that Hungary and a Hungarian language have a code? The also adjustable! Sync 3.4
