Ford Falcon 2008 PATs programming is not available
Hi Guys,
I'm trying to do a PATS programming on a Ford Falcon 2008 Australian made. Both keys are lost. I got two new keys which are cut. Forscan connects and I can perform everything as usual but I can't see any option for PATs programming as you see in the attached picture. A locksmith tried to fix this before for my friend but seems he screwed this up. There is a couple of DTC errors I see and I can't get rid of it. It was quite straightforward when I add a spare key for my Mazda but seems not easy for this ford. Any help is greatly appreciated.
- 4.PNG (35 KiB) Viewed 4877 times
- 3.PNG (24.16 KiB) Viewed 4877 times
Re: Ford Falcon 2008 PATs programming is not available
Did you work this out as I have a 2008 FG with only one key so i will be looking to clear and re-program mine when my new keys arrive.
- Sam1112
- Vehicle: [AUS] Ford Fairmont Ghia [BA Mk2] [4L Straight 6]
As far as I know, the FG is not supported by Forscan for PATS Programming, BA and BF is supported, and although I have not tried, I think the later AU models with SmartShield are supported.
It would be handy if you took logs from your car and sent them to the Forscan team so they can implement FG Key Programming in the future.
Edit: The DTC's that wont clear may be related to having a Key in the Ignition that is not programmed to the car. As seen in your pic it is referring to a PATS Error from a non programmed key.
@Crazy181: not yet, at least I couldn't find anything useful to do PATs yet.
@Sam: Cheers mate, Thanks for the explanation.
- Vehicle: Ford Falcon fg
any info on PATS for FG Falcon 2010?
- Vehicle: SX Territory, 4L, 2009
I would also like to know if this will be implemented soon? I'm also having no luck getting FORSCAN to see the BCM on an FG Falcon. If I can do anything to help, please let me know!
Hi
The Falcon AUII 2001 are definitely compatible with PATS as I did mine last week
when connecting to the car dont use a previous save , has it had a new pcm on it ? if so it will require your as built data putting on it.
Any module that has been changed will need the as built data on it for your car . then try again with the pats .
To the OP did you get this sorted?
- Vehicle: Fiesta XR4,Duratec ST 2.0L, 110kw 2007
Any updates on this guys?
