Speed limiter removal
re875959
Vehicle: 2013 Ford F550 6.7L PSD
Post by re875959 »
Hi guys, This is my first post on the forum so sorry if its been asked before, but I am trying to turn off the 80 mph speed limiter setting on my 2013 f550. I browsed through modules and the super duty spread sheet and couldn't find anything. Any help would be appreciated, Thanks
Juice
Re: Speed limiter removal
Post by Juice »
Can't do it with Forscan. The speed limiter is in the PCM, and Forscan does not support PCM modifications. You need a hand held tuner.
ChuckB
Vehicle: 2013 Super Duty F250 Platinum 6.7 Power Stroke
Post by ChuckB »
I’m assuming it’s the same on a 2013 F250. Does the extended version of Forscan allow modifications to the PCM?
2002 Ford Thunderbird Neiman Marcus Edition
2003 Ford Thunderbird DSB
2013 Super Duty F250 Platinum White 6.7
titanrulez
Vehicle: 2018 f 150 5.0
Post by titanrulez »
I think the speed limiter is in the ecm and forscan cant change the ecm.
Chags007
Vehicle: F250 6.2L 2015
Post by Chags007 »
The speed limiter is in the PCM module. My forscan was able to open it however it stated it was read-only data. I have the OHP wireless adapeter HS/MS can switch.
mmurr588
Vehicle: f150,gas 302 2015
Post by mmurr588 »
the 80 mph thing is part of mykey, you have to disable that. if you have 2 keys no problem if not you have to into the mods
hueypilot
Vehicle: 2017 Ford Police 3.5L
Post by hueypilot »
The above poster is correct. Speed limit is part of "mykey". Read the post by Forscan team on how to delete mykey.
