Keithmac
Post by Keithmac » Sat Sep 28, 2019 6:41 am
Has anybody flashed a Powershift 6DCT450 TCU yet?, where did you all get your update files from?.
LaForge
Vehicle: Ford Focus 2011 - Frostwhite LaForge Edition
Post by LaForge » Wed Oct 02, 2019 6:44 pm
Forscan loads then automatically from the internet
Then you can collect them and flash em onto your module
Best regards
Karsten
riding da White Beast :lol:
ECU Programming Service on Ford Vehicles after 2006
mschumiv
Vehicle: Ford Focus MK4 1.5L 88kw diesel 2019
Post by mschumiv » Wed Oct 02, 2019 8:19 pm
Anyone with a mk4 here?
I flashed the DDM and RCM module, all went well but some functionality changed. Since i wasn't able to flash the PDM module due to some service interrupted error, the windows on the left behave differently than the ones on the right, when using Global close. The left ones close fast at first and on the last 5 to 10 cm, really slow.
I've also lost some selective unlocking features like the ability to unlock only the trunk while the doors remained locked (using the keyless entry feature). Now all doors unlock when trying to open the trunk.
I didn't mess with the anything else but somehow the steering seems to be affected, the level of electrical assistance seems lower, and requires some little extra force to steer.
omar302
Post by omar302 » Thu Oct 03, 2019 4:00 am
I have a 2016 Edge Sport (2.7L Ecoboost). I am also interested in testing. Thanks.
typhoonf2
Vehicle: ford focus 1.6 tdci 2013
Post by typhoonf2 » Fri Oct 04, 2019 4:24 pm
I am also interested in testing, I have a mk3 focus tdci. I also have ford UCDS and a genuine els 27 from Russia plus an elm 327. Thank you.
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Post by davetcollection » Mon Oct 07, 2019 6:49 am
I would really like to be able to have the update function.
I have a Fiesta 2018 1.0 (100) Ecoboost Automatic ST-Line X
Focus MK3.5 1.0 (125) Ecoboost Automatic St-Line
Focus MK4 1.5 Ecoblue Diesel (120) Manual Titanium
I am eager to keep the PCM and TCM softwares up to date on the Automatics, especially the MK3.5 Focus as it's about to go out of warranty
Using ELM 327 Modded
mschumiv
Post by mschumiv » Mon Oct 07, 2019 12:22 pm
Work is in progress, support for Focus mk4 is limited at the moment; not all updated files are available from Ford server, some require paid subscription.
You should avoid messing with the PCM, as you may loose data, that only Ford IDS can reprogram. Best scenario, you get increased consumption.
davidtanis
Vehicle: Ford Fusion 2.5 SE 2015
Post by davidtanis » Thu Oct 10, 2019 4:25 am
Can I still join? 2015 Fusion SE
LaForge
Post by LaForge » Sun Oct 13, 2019 5:06 am
Dear friend,
Do you have done a full recalibration of your doirs?
Before that you have to reset your module to default and then do a relearning of all desired and needed features.
With my mk3 i ve got similar issues after reflashing the ddm and pdm module
Best regards
Karsten
mschumiv
Post by mschumiv » Sun Oct 13, 2019 6:25 am
Dear friend,
Best regards
Karsten
I've downgraded back to original firmware and all is ok.
I still can't flash the PDM module.
