2018 f150 3.5L Ecoboost 10 speeds Tire Size Adjustement
speedy911
Vehicle: 2017 Ford F150
Post by speedy911 » Wed Oct 04, 2017 12:38 pm
Hi I try to reconfigure Tire size on a 2018 F150 3.5L Ecoboost 10 speeds when i try to connect it will show several module and then stop at IPBM i cycle the key off then on and they continue
up to the end then i change tire size in BCM 726-12-01 and after i have code in TCM P160A:00-AF and PCM P160A:00-2F i made a vehicule data relearn with IDS and now the PCM code disapear
i try to erase the code in TCM with no result. Today i will try the same vehicule in 2017 Year Model to see if we have the same issue
speedy911
Re: 2018 f150 3.5L Ecoboost 10 speeds Tire Size Adjustement
Post by speedy911 » Thu Oct 05, 2017 12:48 am
Hi i made some test today on a 2017 F150 3.5 Ecoboost with 10 speeds
i put some log file if some one want to help me to figure out the difference between Fordscan programming 726-12-01 and aftermakket tools that work fine without any trouble code
and when i program with forescan the wrench is on and code in PCM and TCM P160A
the Data for the 726-12-01 is 0163 0A56 565A
Thank
FORSCAN 0A56 TO 0A30 CLEAN.xlsx
(13.14 KiB) Downloaded 159 times
FORSCAN 0A56 TO 0A30 Raw.xlsx
(388.75 KiB) Downloaded 139 times
Aftermarket 0A56 Clean.xlsx
(11.54 KiB) Downloaded 181 times
Aftermarket 0A56 Raw.xlsx
(848.12 KiB) Downloaded 183 times
flasch192
Vehicle: 2017 f150 3.5
Post by flasch192 » Fri Nov 10, 2017 10:22 pm
any updates on this having the same issue
speedy911
Post by speedy911 » Mon Nov 13, 2017 2:10 pm
Hi Flash192
no still the same i wait for tuner coming out on the market to see what is different !!
