Important notes about As Built configuration and programming
Chris@HBH
Vehicle: 2013 Ford Mustang GT500
Re: Important notes about As Built configuration and programming
Post by Chris@HBH » Sat Mar 09, 2019 11:47 pm
ndicars wrote:
Tue Jan 29, 2019 2:38 pm
Unfortunately, the block 726-22-02 has been changed and can not be changed again as described.
Is there a possibility to completely reset a BdyCM control unit?
Or is there another way to solve/bypass the lock?
regards, Andy
HAve the BCM flashed back to stock with IDS or UCDS
Brentb96
Vehicle: 2014 F150 ecoboost 3.5
Post by Brentb96 » Wed Mar 13, 2019 4:07 am
Does anyone have the as built spread sheet for 2014 ford f150?
Narly1
Vehicle: F150 STX 3.7L 2013
Post by Narly1 » Wed Mar 13, 2019 12:10 pm
The "As-built" configuration file (not spreadsheet) is generated specifically for your vehicle when it rolls off the line and is referenced to it's vehicle identification number (VIN). It's a snapshot in time as to how your vehicle was originally programmed so to speak. That way if after purchase the configuration is lost or changed it can be restored.
You can download that file from: https://www.motorcraftservice.com/AsBuilt
If you want a spreadsheet there are several around that decode the configuration values.
See first post in the following thread: viewtopic.php?f=16&t=4393
rkrichter
Vehicle: Ford F-150, 3.5L 6, 2018
Post by rkrichter » Sun Apr 07, 2019 10:53 am
So can I simply download my as built files from this motor craft service instead of going through the process of saving my as built files through FORScan?
flyboy9503
Vehicle: f150 v8 2014
Post by flyboy9503 » Tue May 14, 2019 2:42 am
here it is
2014f150asbuilt.odt
(21.01 KiB) Downloaded 160 times
Outformer
Vehicle: 2015 1.6 ti-vct
Post by Outformer » Mon Jun 17, 2019 8:03 am
My car 2017 ford focus odak
Can you help me activate these features with the forscan program?
Warning when I exceed 120 kilometers
Automatic door locking at a speed of 10 km
notification when I lock the door
alarm with horn
shortening the opening and closing times of the windows
litian520
Vehicle: EcoBoost2.0T/204ps
Post by litian520 » Tue Oct 01, 2019 7:59 am
yes it is
taylorray1986
Vehicle: Ford F-150 5.0 2wd 2013
Post by taylorray1986 » Wed Oct 23, 2019 3:56 am
have you figured out a way to get around the lock yet? after i made some changes my truck ended up in the shop and the ford tech went in and reset everything back to original and now my pcm has locked up and im being quoted $800 for a new pcm because they say that mine locked up becasue it couldnt read the new modules that had been added
Fricke
Vehicle: Ford Mondeo MK5 Diesel 179HK 2016
Post by Fricke » Fri Mar 20, 2020 8:41 pm
Hi
I made several settings in the forscan. But the backup does not work when I would restore.
How do I do now? Is there any way to restore the modules that they were before?
Nervous as hell now. The fog lights are constantly lit and do not switch off. Then it honks when locking.
And it drives strange as well. I'm pretty sure I didn't change anything with those things.
Changed only for tire pressure to appear in the cluster. Kept me away from hex and just to module explaining the camps.
MK5 Mondeo europan modell 2016
Can you please help me.
