Important notes about As Built configuration and programming
Post by FORScan » Mon Aug 07, 2017 1:53 am
Here we post empirical information obtained by us and FORScan users.
1. Write-once bits in configuration memory.
Some configuration bits may have write-once status. It means, they can be changed, but just once. Then they cannot be ever modified. Example - Slave Exists SCL bit in block 726-22-02 of F-150's BdyCM. Outcome is that if no real equipment installed (SCL), module may throw a error code (like U2100 in this case) and some service functions may be not available.
2. Some blocks may be not a real module configuration, but used as a keep-alive memory by modules to store some states (ex. crash event), service events (ex. fuel additive refill) and so on. In some cases direct access to these blocks of data via As Built programming may be limited by module
3. Some blocks of data may have read-only status. So they can be read, but cannot be written. Example: block 720-03 of 2016-2017 Mazda Skyactive IPC module.
4. Sync 3 (APIM module) sends its configuration changes to Ford. So if you change something there, Sync will send these changes when connects to the Internet, and after some time you can see them on Motorocraft site. So far there are no known outcomes of this (like loss of warranty), but it is important to known anyway.
sheltonfilms
Vehicle: 2000 Ford Ranger 2.5L Gas USA / 2013 Explorer LMT
Re: Important notes about As Built configuration and program
Post by sheltonfilms » Sat Nov 18, 2017 5:43 am
Who found #1? Has this been confirmed on multiple vehicles, or is it currently a one time occurrence?
atekin2
Vehicle: ford focus 2015
Post by atekin2 » Mon Nov 27, 2017 2:51 am
I have 2016 Ford Focus. I changed my MFD to SYNC2. However I can not see the APIM to configure camera and navigation in my vehicle. Please help me about how to see and configure the APIM. Thanks
crowhkea
Vehicle: Ford Edge 3.5 L V6 2013
Post by crowhkea » Wed Jan 31, 2018 1:09 am
Does Anybody have a list of as built data list for the 2013 ford edge.
stundentas
Vehicle: mustang escape c-max about few years old
Post by stundentas » Fri Feb 02, 2018 11:18 am
ford edge use 2013 central configuration ;)
se9303
Vehicle: Ford Explorer 4.0L 2006
Post by se9303 » Wed Mar 07, 2018 5:35 am
Hi
Anyone have the “As built” data sheet for a 2006 Ford Explorer 4.0 L? I need to turn off the “park aid” function which my truck does not have but after my PCM/instrument cluster was changed/programmed by a shop Forscan has revealed DTC’s related to lost communication with parking assist control module
Update:
I managed to obtain through Ford the module build data (As-built) using the vehicle’s VIN and through ForScan i have access to the As-built data of each module. Looking through the IC module data there are numerous differences in each of the codes
Considering that my stock PCM was replaced with a used unit, would it be safe to edit all modules and enter rhe data as per the As-built data sheet Ford has provided?
I have coded/flashed BMW DME’s but not a Ford PCM and would appreciate any input to know if its safe to do or if anyone can pinpoint what exactly needs to be edited for the disabling of the park aid function
Upon request i can make the As-built information
Regards,
Mark
hawkeye3043
Vehicle: escape,v6 3.0L,2011
Post by hawkeye3043 » Fri Mar 23, 2018 5:28 pm
Does anyone know if there is a FORScan like software for GM?? I have bought an OBDlinkMX and used it with forscan on my escape and loved it. Need to connect to a gm truck to operate the abs module.
olivo42
Vehicle: 2017 FORD ESCAPE SE 2.0L ECOBOOST
Re: Important notes about As Built configuration and programming
Post by olivo42 » Thu Jul 19, 2018 7:03 pm
About quote #4... I agree... IT IS IMPORTANT TO KNOW that all changes are sent to ford
Soupinski
Vehicle: New EcoSport 2.0 147cv 2013
Post by Soupinski » Fri Aug 03, 2018 12:03 am
ndicars
Vehicle: Edge, V6 2700ccm/235kW, 2016
Post by ndicars » Tue Jan 29, 2019 2:38 pm
Unfortunately, the block 726-22-02 has been changed and can not be changed again as described.
Is there a possibility to completely reset a BdyCM control unit?
Or is there another way to solve/bypass the lock?
regards, Andy
