2017 XLT F150 Trailer Brake Controller Activation
jeffbaustin
Vehicle: 2015 Ford F-150 XL 3.5 EcoBoost
Re: 2017 XLT F150 Trailer Brake Controller Activation
Post by jeffbaustin » Wed Aug 09, 2017 2:24 pm
lmcfarlin wrote:Hi jshanehood, I too wanted to thank you for the video. I was able to turn on the factory trailer brake so I too get it to come up on my screen, but when I squeeze the trailer brake manually it doesn't show on the screen. The reason I ask is we use the f150 xl for work trucks and they come with trailer brake already installed and when I squeeze the one in the work truck it says something like (no trailer attached). Is there something else I need to do? Thank you Larry
Hi lmcfarlin. Did you get this to work? I just did this last night on my 2015 F150 XL and it worked like a champ. I followed the video, but my options in the IPC module were slightly different. One said something about showing the trailer controls on the screen, and the other was simply to enable the TBC just like in the video.
BrooklinCheetah
Vehicle: F150 XTL, 3.5 ecoboost, 2017
Post by BrooklinCheetah » Fri Aug 11, 2017 1:33 pm
Hello all, I'm new to this board and am in the same position as the op. Where can I get the extended license? I've bought the obdlink mx Bluetooth and can connect but it says I need the extended license to add the trailer brake controller and gain . I can't wait to see what other things can be added to my truck. Thanks in advance.
jeffbaustin
Post by jeffbaustin » Sun Aug 20, 2017 2:02 pm
lmcfarlin
Vehicle: Ford F-150 2.7 ecoboost 2017
Post by lmcfarlin » Mon Aug 21, 2017 3:08 am
Yes I did
heibe
Vehicle: ford super duty f250 2017 6.2
Post by heibe » Fri Jun 01, 2018 12:21 pm
Hi everyone I just scanned my vehicle and in my ipc module configuration I only see trailer brake control module unable to find the trailer brake controller gain setting to enable.
I have a 2017 f250 xl
Thanks for the help
Vladsky
Vehicle: 2017 Ferd PHEV
Post by Vladsky » Fri Jun 01, 2018 12:48 pm
heibe wrote:Hi everyone I just scanned my vehicle and in my ipc module configuration I only see trailer brake control module unable to find the trailer brake controller gain setting to enable.
Thanks for the help
http://forscan.org/forum/viewtopic.php?f=16&t=6592
Post a screenshot of all yer IPC As-built data listed by Forscan.
Vlad
AlexJ1870
Vehicle: F-150, 2.7L Ecoboost, 2017
Post by AlexJ1870 » Fri Jun 29, 2018 4:45 pm
What device do I need to connect my laptop with Forscan extended license to my 2017 F-150 to program a OEM brake controller?
This ELM327 has a switch for MS ir HS, but a previous post said they do not work despite reviews saying otherwise on amazon?
https://smile.amazon.com/OHP-ELMconfig- ... B01F0GVBWY
Just looking for a good, cheap way to activate the brake controller.
Mkmayor
Vehicle: F150, 2.7L eco, 2017
Post by Mkmayor » Tue Sep 11, 2018 11:25 pm
Hey alexj1870, did you figure it out? Did you make the switch work?
Vehicle: *** Ford ***
Post by f-wolf » Tue Sep 11, 2018 11:35 pm
Trailer Brake.jpg (14.72 KiB) Viewed 2010 times
Mkmayor
Post by Mkmayor » Wed Sep 12, 2018 3:14 am
F-wolf, which OBC reader did you use, did it have a cann switch?
